P0302 cylinder 2 misfire detected
Discussion in 'Gen 3 Prius Main Forum' started by Prsguy, Mar 16, 2022.
  1. Prsguy
    Prsguy New Member
    we were On the freeway going 40mph but the engine vibrated hard when tried to accelerate above 45mph so pulled over into a parking lot and turned off the car.
    It was very weird. Never had such an issue before.
    When I started the car again in couple minutes, there was heavy knocking or grinding noise from the engine without even touching the gas pedal.
    After an hour I tried to see if the car was drivable and I was able to drive it around the parking lot. There was no issues with gear shift or reverse gear but the noise was still there.
    We didn’t want to bother risking so left the car at the lot and took an Uber home.
    This morning I tried to check the code with my off brand OBD II and it showed P0302 cylinder 2 misfire detected.
    After calling around mechanic shops, finally found a mechanic who said that they work with Prius’.
    Took it there and now the shop has sent an email saying
    The Drive Unit/Transmission has internally failed. Grinding & Popping at the LH Side of the Case. /// The Drive Unit/Transmission will have to be Replaced.
    what should I do?
    Can I trust the diagnostics report from the mechanic? Does transmission failure show any symptoms on gear shifts and drivability?
    I have not had any major repair experience with cars so far and My wife is very worried that we might get ripped off. Just thought I would have a running thread with other Prius owners and others who might be familiar with the issue until I get my car fixed.
    TIA
  2. JC91006
    16,928
    8,637
    You should take this car to the dealer to get a proper diagnosis. This mechanic you brought it to is just trying to empty your wallet. The code is a misfire engine code, and they are telling you it's your transmission. It's an engine problem, not transmission.
    These cars are notorious for a head gasket failure. So you might get that bad news after a proper diagnosis
    Mendel Leisk and Prsguy like this.
  3. Tombukt2
    Tombukt2 Senior Member
    13,779
    2,495
    Durham NC
    Pull no2 spark plug See water droplets on that plug end or tip look carefully at the ceramic China portions see droplets smell then smell pink water jug in car ... me smell eh?? Coolant in cylinder bore or hole . I just went through this . Just recently 2013 208,000 miles no 2 same as yours . Tried head gasket meccie missed fissure crack in piston crown . JDM engine ordered. Installed
    Prsguy likes this.
    52,740
    how many miles on her?
  5. Prsguy
    Prsguy New Member
    Update:1
    This is the same exact noise I have in my Prius.
  6. Prsguy
    Prsguy New Member
    198045miles
  7. Prsguy
    Prsguy New Member
    Update:2
    The mechanic called this morning and said that the CVT transmission has failed and we have to fix that. When I asked about the cylinder 2 misfiring and it’s relation the CVT failure, they basically said that they haven’t focused on that because the CVT is broken and it needs to be replaced first.
    I have received the following quotation:
    OER/LKQ hybrid unit (with 60k miles on it)
    OER fluid
    For almost 3k
    wondering if I should just move the car to a dealer or another mechanic if I can find any.
  8. Mendel Leisk
    42,219
    Is engine coolant level stable in the reservoir?
    Have you ever heard of EGR cleaning? Best done every 50k miles, and dealerships won't even tell you about it, let alone do it. (More info in first link in my signature.)
  9. PriusCamper
    PriusCamper Senior Member
    13,364
    5,402
    Pacific Northwest, USA
    Mechanic's diagnosis is NOT consistent with symptoms, nor is it consistent with what usually is broken when these symptoms come up. Call 'em up and tell them that engine misfire error code is not a transmission problem and they need to look at it again.
  10. Mendel Leisk
    42,219
    I think failing head gasket has lead to broken damper, twixt engine and transaxle. But yes, just collateral damage.
    CR94 likes this.
  11. rjparker
    rjparker Tu Humilde Sirviente
    10,940
    6,862
    Texas Hill Country
    What is OER?
    If the mechanic has not seen this early head gasket problem before and is just going by the noise, it is easy to think severe mechanical damage. However a typical early gen3 head gasket leak tends to run fine after it warms up. A severe damper or planetary gear failure won't smooth out and run fine. Warm it up and test it.
    If you need something expensive it is more likely to be an engine.
    To understand this better, a coolant leak into the cylinder will foul out the plug causing a misfire. This causes the transaxle to lose sync with the engine which is critical 100% of the time when in Ready. The damper slips causing the metal to metal sound. Lost rpm sync goes away once the plug starts firing again. If it does not go away quickly then it could be a "hard" misfire caused by plugs or coils.
    A permanent misfire due to a bad plug (possible) or coil (uncommon) can cause a continuous "rattle" that does not clear. Changing the plug and coil (or moving) will id this possibility. But if it clears just by warming it up, it is typically the hg. While not recommended long term, a coolant sealer that clears the problem is also definitive. Sometime a borescope inspection will show a steam cleaned piston. But that test and a leakdown test is not definitive if it passes early in a hg leak progression.
    #11 rjparker, Mar 16, 2022
    Kasra likes this.
  12. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    Those guys that made that video are the experts in the field.
    Go to their web page https://www.gasketmasters.com/
    give them a call - explain and ask for a recommendation in your area.
    I swear I saw some affiliate shops in TX a month or two ago that are not listed now.
  13. Kasra
    Kasra Member
    49
    27
    Irvine, CA
    I have a Gen 2 Prius that does this. Could this be caused by dirty injector? I felt the grinding feeling today when the car was in drive and waiting at the stop sign. It went away when I put in in park, but again I felt it in Drive. It went away when the engine warmed up.
    What it felt like? (Almost like when the brake rotor is rusted and you brake coming to a stop). My plugs are new and I don't have a coolant leak (120K miles), so my next item is cleaning the injector.
  14. ChapmanF
    18,919
    Any Prius where the engine is misfiring—for any reason—will make a horrendous racket from the transmission that sounds like it is banging itself to smithereens. The reason why is explained in this article, especially under "why the knock?" on page 4. There are heavy electric motors in there that the car's computers are trying to keep spinning in exact synch with the engine rotation, and when the engine misfires, that doesn't work out.
    A nitpick, the damper slipping in there is not what makes the horrendous sound. The damper is put there to slip in just such circumstances to protect things, and the sound would be even more horrendous if it did not.
    However, if the misfiring goes on long enough, springs in the damper can be pounded to bits and fall out (you can scoop spring bits out of the bottom of the bell housing), and with the springs gone, the sound will be even more horrendous. It can eventually cause the transmission input shaft to break. (Once that happens, you won't even be able to start the engine, because in a Prius, the transmission is what does that. The glass-half-full version: if you can still start the engine, the input shaft hasn't broken yet.)
    So if this mechanic is thinking "I shouldn't troubleshoot this misfire, because the transmission sounds horrendous", it's possible the mechanic just doesn't understand that's the way things always sound in a misfiring Prius. You could send along the article linked above. (In that article, an owner let a Prius go for scrap price, and the issue turned out to be a single bad spark plug.)
    On the other hand, it's possible the mechanic has additional evidence that there really is a transmission problem.
  15. Mgoddard92
    Mgoddard92 Junior Member
    22
    I am having a issue with cylinder 2 miss firing as well, this happened after changing the timing chain gasket, I released the tensioner and verified everything was still on time. What I did do wrong was start the vehicle without putting the spark plugs in *bonk*. After putting the spark plugs in, the major knocking and miss firing stopped but now am getting a p0302. Could this be because of un burnt fuel fouling that spark plug, from the engine running for 30 seconds with no plugs installed? Sorry guys just trying to get my 5 post so I can be seen lol
  16. PriusCamper
    13,364
    5,402
    Have you moved the ignitions coils to different locations to see if misfire moves with it?
  17. Mgoddard92
    22
    Not yet I am going to do that tonight once I get home. I'm hoping it's just a coil or spark plug and not the new freaking head gasket lol
  18. Mendel Leisk
    42,219
    When/why did this happen? What's the miles?
    Looking through your posts, see you've mentioned head gasket replacement several times. Can you give more info? What symptoms lead to head gasket diagnosis?
    There's a question I'd like to ask, but I don't want to "lead the witness"...
  19. Mgoddard92
    22
    198000 miles, So about a month ago my Prius started developing a gnarly misfire at stop lights, throwing P0301, so I replaced cylinder 1 spark plug and coil pack, didn’t fix it. A week later it was really low on coolant, and now had p0302 and p0301 ,and no visible leak. At that time I decided to tear into the head and when doing so piston 1 was washed….
    Had a valve job done on head and reinstalled. While I was there I replaced both timing chains (oil pump chain), all the guides, new crank sprockets, and chain tensioner.
    got everything back together and when I started in maintenance mode I had the check hybrid system message, but no misfire. Overall the car idle very nicely…. I bleed the coolant system and proceeded to use the vehicle to see if a drive cycle would clear the warning message on the dash.
    while it was in the driveway I noticed a puddle of oil and found the new tensioner was leaking, replaced and then that’s when I had the fumble mentioned in my previous post
  20. Mgoddard92
    22
    So I swapped ignition coils, and cylinder 2 is still miss firing, I will change the spark plug tomorrow and swap injectors after…. Could it be the harness from peeling it back three times in the last month?
