P0401 Check Engine Light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Zoddy, May 4, 2018.
  1. Zoddy
    Zoddy New Member
    Pk
    Hi - I have prius 2010 98000 driven. I had P0401 with check engine light. Got Egr cleaned along with pipes, throttle body n MAP sensor. I didnt clean the intake manifold after opening, but client the passage it has to egr. Now the light is back almost about after 100k. What next should be done?
    #1 Zoddy, May 4, 2018
    Prius_Angie likes this.
  2. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    You should clean the intake manifold too. There are four small return secondary ports that can clogged up with grime.
    Additional questions:
    Does your engine consume oil?
    Was the PCV valve replaced?
    You mentioned EGR cleaned. Does it include the EGR cooler?
    Prius_Angie and Raytheeagle like this.
  3. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    Original 12v battery?
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,699
    1,746
    Bay Area
    You need to clean the whole egr system. It’s probably clogged with carbon. I would clean the egr cooler, pipe and intake manifold. If you cleaned it once before with the code and it went away, and now it has return, it’s probably has a build up of carbon over time.
  5. orenji
    orenji Senior Member
    5,887
    3,488
    EGR valve been replaced? If not its covered by Toyota for 15 years or 150,000 miles.
    Prius_Angie and Bay Stater like this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    While the valve is covered, that replacement won’t solve the underlying cause:(.
    Stories here point to the valve getting replaced, but everything else in the circuit being left “as-is”;).
    Cleaning the circuit is the best solution for the symptom (y).
