P0402 EGR ?2001 prius 1.5
Discussion in 'Generation 1 Prius Discussion' started by Kelly C, Feb 2, 2018.
  1. Kelly C
    Kelly C Junior Member
    2001 Prius
    I have a 1 gen prius 2001 1.5l. Pops code P0402 every so often. Runs fine no other symptoms. Can't for the life of me figure it out. I can't find any info on an EGR valve on this little motor. Any ideas out there?
  2. sandy11246
    sandy11246 Member
    71
    39
    kansas
    2003 Prius
    That code does relate to EGR, but wondered if the DTC may have actually been P0420. I could not find any relation to a P0402 on a 2001 Prius. Just asking and trying to help. I have a 2001 Prius repair manual but no listing of a P0402 DTC. Weird.
  3. Kelly C
    2001 Prius
    Yes I’m sure of the code and that’s the problem I’m having I cannot find it in the manual anywhere and I cannot locate an EGR valve on this vehicle
  4. sandy11246
    sandy11246 Member
    71
    39
    kansas
    2003 Prius
    What scanner was used to extract the code? Mini VC or other.
  5. ChapmanF
    15,407
    No P0402 in the code list, and no EGR on the Gen 1 engine. Look as hard as you want. :)
    Funky code reader used to read the code? Engine ECU replaced with a wrong one?
    -Chap
  6. sandy11246
    sandy11246 Member
    71
    39
    kansas
    2003 Prius
    I agree Chap, that was exactly where I was going. I would have to be one of those two choices. If it appeared more than once, and it set an CEL I would consider the wrong ECM. If just a DTC w/o CEL, code reader is issue.
