P0420: Catalyst Efficiency
Discussion in 'Gen 3 Prius Main Forum' started by abd25524, Mar 25, 2021.
  1. abd25524
    abd25524 Junior Member
    MN
    I'm running my 12 prius with P0420 staring at me from the dash. With some footjob :)p), I still manage to get 50+ mpg, coasting, gliding, downhill advantage, etc. I got the car with this code. Don't know the history. Here are my findings and actions:
    1. The CAT temp is equal at both ends.
    2. Downstream O2 sensor jumps up and down.
    3. Previous owner replaced the O2 sensor within 6 months.
    4. I replaced the PCV valve, intake was oily. Planning to install a catch can next time.
    5. Car struggles in ramp/uphill.
    When the mode switches to PWR (gas run), I get <20 mpg. Does this indicate that I should hurry to replace the CAT? I assume it's $2000+ repair with OEM unit w/ heat recycle. After market CAT from rock auto didn't seem a feasible option because of no good welding clearance and the heat recycle system.
    How long can I delay on this CAT service? I don't live in CA. Any experience sharing on the cost to replace the CAT is appreciated. Thanks.
    52,595
    how many miles on her?
    from what i have read, a good after market cat is only a few hundred, if your state allows it.
  3. abd25524
    MN
    159k miles. I believe that the after market cat is allowed here. Thanks for the suggestion.
  4. abd25524
    MN
    Anyone got any luck with the cleaners (pouring through fuel tank) to unclog the Cat?
