P0420 Catalyst System Bellow Threshold Bank 1?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KitsuneVoss, Jan 25, 2025.
  1. KitsuneVoss
    KitsuneVoss Member
    262
    42
    Virginia
    The code P0420 Catalyst System Bellow Threshold Bank 1, is that usually the upstream oxygen sensor?
    I know ti was with my 2001 Mustang.
    Also, are there any less expensive oxygen sensors than the Denso that work reasonably well?
    Looks I will have to do it myself because most mechanic shops now will not yet you buy the parts
    Make various bullshit claims but they will buy the part from an auto part store and triple the cost. .
  2. ChapmanF
    17,009
    The ECM uses both the upstream and downstream sensors, and control of the engine mixture, to test the effectiveness of the catalytic converter, and report this code if that effectiveness has dropped below threshold.
    So the code is usually about the catalytic converter—that's the purpose of the test and the purpose of the code. Cases where the problem turns out to be one of the sensors just used for the test aren't impossible, but jumping there as a first guess would be like shooting the messenger. There are individual trouble codes for both sensors that are likely to be set if those aren't shipshape.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,925
    1,889
    NJ-USA
    The catalyst monitor test is fairly complex and requires a number of functional systems in order to be accurate.
    Replacing parts based on assumptions can: get expensive, not fix the problem, and cause new problems. (you might get lucky, but it's your money)
    When I diagnose a P0420, I make sure - 1) there are NO exhaust leaks anywhere at or upstream of the converter, 2) both A/F (S1 - upstream) and O2 (S2 - downstream) sensors can accurately report full lean to rich range, 3) the engine runs properly (total fuel trim is 0 +/- 10%, and NO misfires) 4) there are no applicable service bulletins (TSBs)
    IF all those are true then the car needs a new cat.
    5) if the engine uses-burns lots of oil - that killed the old cat and will kill a new one as well.
  4. KitsuneVoss
    KitsuneVoss Member
    262
    42
    Virginia
    Those answers may actually help me. I think the car is running a little on the rich side due to what appears to be low, but not crazy low, MPG compared to my previous car. What tends to cause a Prius to run rich?
    Did read MAF sensor and I plan to clean the MAF sensor soon. I think it is suppose to be 60 degrees Wednesday, so not a bad day to try to do it. Do I need to strip the throttle body and clean it? The same Mustang that I changed out the oxygen sensors, which were only like 20-30 each, I stripped the throttle body and cleaned it.
    I don't mind throwing a few dollars worth of parts at a car but the Denso oxygen sensors are really expensive but new gaskets for throttle bodies are generally a different category.
  5. MAX2
    MAX2 Senior Member
    1,423
    465
    101
    Third planet from the Sun
  6. douglasjre
    douglasjre Senior Member
    2,062
    691
    Null, NL
    You're wrong about everything you said for reasons you don't comprehend.
  7. KitsuneVoss
    KitsuneVoss Member
    262
    42
    Virginia
    Thanks, that is very unhelpful.
    Does it make you feel good just writing that?
    The thing is that my past experience with that code in a different vehicle was that it was the O2 sensor
    My other experience is that mechanic shops upcharge significantly the parts they buy, sometimes not just by 10% but by 100 to 200%.
    They used to also be more willing to put parts you buy for you.
    I write here to be helped, not to be called stupid.
    #7 KitsuneVoss, Jan 26, 2025
  8. frodoz737
    frodoz737 Top Wrench
    4,474
    2,415
    33
    Find a competent shop to T/S this before you just throw parts at it. That's my friendly.
  9. KitsuneVoss
    KitsuneVoss Member
    262
    42
    Virginia
    In the past, both on other cars and specifically with a Prius, I have found it cheaper to throw parts than to get a diagnostic check.
    The sensor is real expensive and the conversation here is that it is not likely to be the sensor.
    If there are a number of small things I can do that are not real expensive, I would like to try them first.
    Those are the answers I was hoping to get, little things I can try first.
  10. frodoz737
    4,474
    2,415
    33
    The system is actually very simple, but you need test equipment to T/S. Best wishes...I'm off.
  11. KitsuneVoss
    KitsuneVoss Member
    262
    42
    Virginia
    I have T/S actually. I thank Max2 for providing that sheet but I will have trouble following it.
    Is there a video which shows actually how to do it?
  12. rjparker
    rjparker Tu Humilde Sirviente
    9,320
    5,682
    Texas Hill Country
    1. Does your engine burn oil?
    2. Have you checked the values produced by the monitor?
    3. The aftermarket sensors can be a problem with bad quality. However I have used a Bosch aftermarket O2 on a gen2 after the cat and downstream sensor was stolen. The Bosch has different wire colors so read and follow the instructions. However as indicated above, a bad sensor or wiring will usually have its own code.
    4. The odds are 95-98% your set of cats are bad. If it's oil clogging your mpg and maybe driving reliability is at risk. After spending (wasting?) money on sensors you can get a new set of cats. Assuming you are in a non-CARB state, an aftermarket gen2 set of cats that works is a Walker 16337 ($160 - $271).
    #12 rjparker, Jan 26, 2025
    douglasjre likes this.
  13. KitsuneVoss
    KitsuneVoss Member
    262
    42
    Virginia
    I did just change out the spark plugs and did not seem especially bad. Have had it for about three weeks now. How would I verify if it is burning oil?
    Need to plug in the T/C and see if I can find the test screen you are referring to.
    How hard is the cats to replace? Looks a lot smaller than the one on my Mustang at least. It cracked on my mustang and jad to get it welded.
  14. douglasjre
    2,062
    691
    Null, NL
    How much oil does it burn, and did u use diesel grade oil?
  15. rjparker
    9,320
    5,682
    Texas Hill Country
    You need to top it off and drive 500 miles. Then check dipstick. Many of these burn oil at high miles which can clog cats.
    You have to unbolt cats at exhaust and cut them off downstream. Some have clamped the new cat to the cut side - most would have it welded.
    KitsuneVoss likes this.
  16. KitsuneVoss
    KitsuneVoss Member
    262
    42
    Virginia
    Ouch, I have to cut and find someone to weld them.
    I was hoping the cat at the muffler were separate and bolted together.
    Some cars are like that.
    I know my 2009 did go through some oil but never seemed to cause this code.
    I am not getting the code all the time as well, more or less intermittently
  17. saneesh8
    saneesh8 Junior Member
    113
    22
    Allen, TX
    My 2009 with 150k have this. I tried Liqui Moly Catalytic System Clean and it went away. But it came back after 1-2 fill ups. It was burning like 1/4 qt with 2-3k oil changes. This time i added Auto-RX engine cleaner with a NAPA brand synthetic oil. So far after 1k miles oil level hasn't dropped. Also the frequency of the the P0420 has reduced. Not sure if the warm weather helped or the cleaner helped. Previous history i could find was not great. Irregular oil changes and regular oil was used and was done at quick change places.
    I never had to replace the cat. Rock Auto have it for decent price. But have to cut it and tie it with clamp. Seems not difficult. I may do it in the near future if needed.
  18. KitsuneVoss
    KitsuneVoss Member
    262
    42
    Virginia
    The Liqui Moly Catalytic System Clean is pretty cheap, $20 on Amazon. Worth a quick try at least.
    How does it work? Do you spray it in or does it get added to the gas?
  19. saneesh8
    113
    22
    Allen, TX
    Just add it to gas. Also after that use the gas with detergents. Costco have the highest.
    BTW how much oil does it burn? Use only full synthetic oil. Read good reviews about Valvoline R&P. After the Auto-RX, i am going to try it and oil change every 3k miles.
    My teenage son drives it. So not a soft drive. I guess it helps the cleaning process also.
  20. KitsuneVoss
    KitsuneVoss Member
    262
    42
    Virginia
    Second question. . . . .Assuming it is burning excessive oil, what is to be done anyway? Should I still replace the cat provided the chemical attempts fail?
