P0420 code after....
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by douglasjre, Sep 14, 2020.
  1. douglasjre
    douglasjre Senior Member
    1,877
    651
    Orlando, FL
    Put in a new $99 ebay cat. Same codecoming up again. Advice? (And don't say clear the codes)
  2. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    You got code 0420 and replaced a cat?
    Did you test the O2 sensor first?
    Did you inspect the wiring and connector to the 02 sensor?
    If all is functioning correctly, and if the new cat is higher flow than OEM, then an 02 sensor extender may keep the code from resetting.
    Good luck.
  3. douglasjre
    1,877
    651
    Orlando, FL
    PXL_20200915_004829326.jpg PXL_20200915_004841206.jpg PXL_20200915_004852849.jpg PXL_20200915_004904899.jpg I did test the sensors. Here's the data I'm getting on a handheld. I'll pull it up and techstream again tomorrow
