P0420, P0441, P2501, P0803 - 2006 Prius 230K miles
Discussion in 'Gen 2 Prius Technical Discussion' started by Bryan Holloway, Jul 27, 2016.
  1. Bryan Holloway
    Bryan Holloway Junior Member
    43
    Fullerton, Ca
    I have a P0420 code that sets off and not able to pass smog I started looking into it. After watching my downstream O2 fluctuate from .1-.4 before cleaning, now after cleaning its at .1-.8. The code still comes back right away.
    Also I noticed I am able to look at the "Readiness codes" on the programmer. It gave me one false code, a P0441 (Evaporative Emission Control (EVAP) System Incorrect Purge Flow), P2501, and a P0803 (1-4 Upshift Skip Shift Solenoid Control Circuit Malfunction). Is it possible the EVAP might have something to do with this P0420 code?
  2. Bryan Holloway
    43
    Fullerton, Ca
    Anyone have any experience with these codes?
    51,155
    are you using tech stream and the service manual?
  4. Bryan Holloway
    43
    Fullerton, Ca
    No im using the Innova 31603 CarScan + ABS/SRS Scan Tool. No service manual =(
  5. niphonk98
    niphonk98 Junior Member
    San Francisco
    I got the P0420 the same. I look the code have 3 problems.
    #1.O2 sensor
    #2.Mass airflow sensor
    #3.Catalytic convertor
    I fix the temporary problem by use the scanguage to scan and clear the code.
