P0420 - seems eventually it's the Cat. anytime anything else?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Andrew Vanis, Jul 13, 2018.
  1. Andrew Vanis
    Andrew Vanis Junior Member
    Albuquerque
    Topics researched that discuss replacing the o2 sensors (ok, the fuel mixture sensor to be technical about the upstream one) eventually seem to say replacing the cat solved it.
    Anything else to check before doing the cat or just replace the cat and see what happens?
    i don't have the nuanced tools to accurately read o2 feeds and reading posts such reads doesn't seem conclusive anyway (though I do have torque but topics say that the o2 readings from that aren't accurate) . I'd rather toss a few hundred $ at the likely cat solution.
  2. Tynyyn
    Tynyyn Member
    102
    27
    Bella Vista Arkansas
    I've been dealing with a P0420 for a month now. My
    04 Prius has 240K on the clock and it's been driven a bit roughly by a construction worker. That being said, when I drove a way from the fellow I bought it from the CEL popped up and now I owned it. oh well.
    I've been thinking about a solution to the problem with a bad cat. There are basically three parts to the problem with a few other little bits tossed in. First is the Upstream O2 sensor, the Cat, and the downstream sensor. Also a little bit of extra air slipping into combustion chamber or a bit of oil getting burned will contribute to the problem.
    A p0420 tells the operator that the cat is dead. Somehow I do not believe my cat is dead. Maybe a sensor, but not the cat. If the cat were dead, then it would be clogged and the engine would bog down and acceleration would be horrible. Thus, I believe the cat is still functional, yet not dead.
    Now, onto the sensors. If the upstream sensor were bad, it would/might give inaccurate data to the pcm. I watched a YouTube vid of a prius with a dead cat and the tech using a computer to see the graph of both O2 sensors. The upstream sensor was bumping up and down(which is normal) while the downstream cat was doing the same thing(it should be a straight line going across the graph). The tech then changed out the cat and it fixed the problem. The downstream O2 sensor was now flat lining. So this tells me that the upstream sensor has a set value and the downstream sensor must have a different value. How to get the downstream sensor to have that differing value? New sensors, new cat, tighten up air leaks, or...…….clean the cat somehow.
    Onto cleaning the cat....I've seen youtube vids where folks soak their cats in differing types of liquids in order to scour the build up off the honeycomb areas. To me, that seems like a good idea expect it would mean taking off the cat and then finding a way to soak it. Too much work for me. So I decided to go a different route to clean the cat. On a thread somewhere within PriusChat a member stated that with each fuel tank fillup he would add a bottle of Techron. After six applications, the P0420 went away. I became interested in this way of cleaning the cat so I began doing the exact same thing. First tank filled up and a bottle of Techron was added. Second tank was the same. Now comes the third fillup and I could NOT find Techron at the gas station so I used Lucas engine treatment in the small bottle. I've put about 50 miles on this tank of gas and when I went to start my Prius after work tonight I noticed the P0420 light was out. All the way home I was thinking the light would flick back on, but it stayed off. So maybe the Lucas is the cleaner my cat needed.
    Each tank of gas lasted about 325 miles and the amount of gas added was 8.25gal and 7.00gal. So after about 700 miles my cat light went dim. I'm tentatively happy and hope the light stays off. Cross my fingers
    Also I made sure I tightened up all the intake manifold joints, added Mobile 1 syn oil 5w30, also some MMO in order to lube the rings. The plugs looked good, but have a lot of miles on them.
    So, in summary, for the price of two tanks of gas, two bottles of Techron, then a partial tank of gas with a bottle of Lucas engine treatment I might have solved my P0420 problem
    Hope this helps somebody.
    SFO likes this.
  3. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Can you please link to that thread here?
    Thank you.
  4. JC91006
    16,474
    8,393
    This type of cleaning will be very disappointing when the light comes back in a few days
  5. Tynyyn
    Tynyyn Member
    102
    27
    SFO, I'm trying to find the link but I come up with NADA. Sorry. But I do know I saw it on this website.
    JC91006, you might be right, but I certainly am at least temporarily happy. Feels good after all the disappointments in my life lately.
  6. JC91006
    16,474
    8,393
    We had a member that used an acid solution to clean it (on YouTube), worked just enough to pass a smog check and the light returned.
  7. Andrew Vanis
    Albuquerque
    Update on my side (the original poster)...
    Could be unrelated but no active P0420 CEL for me after I replaced the spark plugs and PCV valve while I was in there replacing the transmission. The old plugs were within gap and a little oily. The old PCV valve was still rattling but didn't sounds as 'crisp' when rattling compared to the new one. The P0420 CEL still shows pending under Torque and comes back as pending after clearing but it is not becoming an active code.
    Could be that I just had the 12v battery unplugged for the tranny replacement. It has been several hundreds of miles since then and no active P0420.
    Personal (unprofessional) theory is that the new plugs and PCV valve cause cleaner burning so less stuff ends up in the cat.
    I'll update if things change.
    chelvis and SFO like this.
  8. Tynyyn
    Tynyyn Member
    102
    27
    Well, all good intentions go to waste at times. Seems that I wrote a long diatribe on what I thought was a good solution for a common problem only to smack my self in the face when the CEL popped on again. T'was then that I had remembered that I disconnected the negative battery cable to fiddle with my cruise control and clock spring. My "wonderful" solution truly hasn't kicked in yet. Only a reset of the CEL. Maybe if I'm lucky in a couple more tanks of gas my idea will come to some sort of good result. In the mean time, know that I'm still waiting for a positive result. UGH!!
