P0446 code and then warning lights and red triangle
Discussion in 'Gen 2 Prius Main Forum' started by TeamPriusNewbie, Mar 3, 2024.
  1. TeamPriusNewbie
    TeamPriusNewbie Junior Member
    Chicago, IL
    Hi all- hoping to find others who have experienced this issue, or have knowledge to share either way. Have been having an issue with my 2005 Prius (146k miles) throwing the P0446 error code (Evap Emission Control System Vent Control Malfunction). Happens primarily when the gas tank hits just below half. Opening the gas cap and reclosing it tighter works, then clearing the light, until the next time the tank hits just below half when the light comes back on. Assume a seal needs to be replaced, but I'm procrastinating b/c I just sunk a lot of cash into two new ball joints.
    Last week the light came on and I just left it, meaning to run the code and then clear it. I did open/close the gas cap more tightly, just didn't run the scan or clear the light. Today I got gas, about 1/2 tank to fill it, and then closed the cap tightly, check engine light was still on and I made a mental note to clear it when I got home. After 30 seconds of driving, multiple lights popped on including the red triangle. Car was running fine, so I continued driving the 10 minutes to home. When I arrived home I connected the scanner, cleared all the lights, everything went away. Powered on and off several times, still clear. Drove around for 12-15 minutes, still clear.
    Seems to much of a coicidence with the timing of getting gas to have this not be related to the gas or gas cap, but would that cause the triangle?
  2. ChapmanF
    15,702
    What hybrid system code caused the triangle to light up?
    Do you have a scan tool that shows the hybrid system codes?
    If not, some are reviewed in this thread:
    Gen2 OBD2 app review | PriusChat
    TeamPriusNewbie likes this.
  3. TeamPriusNewbie
    Chicago, IL
    I doubt the scan tool I'm using shows hybrid system codes- so I cannot say. The P0446 is what has been causing the check engine light to pop on every month or so for about 6 months now, and thats also what came up today. When I cleared that code, it cleared the check engine light as well as the red triangle, neither have come back on.
  4. TeamPriusNewbie
    Chicago, IL
    Turns out a family member did have an OBD bluetooth plug in scanner- it did not find any codes, likely because I cleared them when I arrived home earlier. I plan to drive it locally through the neighborhood tomorrow, but not sure what other than the code related to the fuel could have triggered the red triangle. gas mileage still at 56mpg, 7 out of 8 bars on the battery consistantly, no performance issues.
  5. ChapmanF
    15,702
    Keep in mind that there even are OBD bluetooth plug in scanners that don't show all information for a Prius. So, while it's good a family member has that, you might still plug it in one day when the triangle light is on and have it tell you there aren't any codes. That does happen to people.
    If it happens to you, you can look through the thread linked in post #2 for other scan tool options that can work better.
  6. Tombukt2
    Tombukt2 Senior Member
    9,220
    1,618
    Durham NC
    When all the lights come back on again use your scanner your friends scanner any of them and see what code you get while the lights are there don't just clear them or are you saying you read them while the lights were on and couldn't get any reading of codes but you were able to clear them?
