P0505 -- Am I the only one?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Absalom, Jan 21, 2019.
  1. Absalom
    Absalom Junior Member
    42
    42
    Denver
    2010 is throwing a P0505. I can't find a single thread for the Gen 3's where someone else has this issue. Any suggestions on where to start?
    52,351
    what are you reading it with?
    52,351
    i found some threads. pat wong suggests starting with throttle body and plate cleaning.
    check engine oil cap o ring, dip stick and pcv hoses for leakage
  4. Mendel Leisk
    41,863
    How many miles on it?
  5. Mendel Leisk
    41,863
    I'm normally drawn like a moth-to-a-flame to EGR as culprit, but there is a separate code for that, maybe P0401.
    Attached is the main section, looks pretty deep, requiring Techstream. Wouldn't hurt to check the PCV connections, try replacing PCV valve (it's cheap) and cleaning the throttle body first though.
    #5 Mendel Leisk, Jan 21, 2019
