P0505 code thrown....any ideas?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by frtsniffr2004, Sep 26, 2013.
  1. frtsniffr2004
    frtsniffr2004 New Member
    Hey all,
    yesterday my 04 with 143k threw a CEL. checked it and it turned out to be a P0505: idle control system.
    Can i get away with tearing the throttle body apart and cleaning it as well as the MAF? I had an acura, that i had to service the IAC valve in the throttle body and i never had a problem again.
    Is there anyway to determine if this will need a new throttle body in the future? after i cleared the code it did not come back on and the car is still driving normally getting 54mpg
    Thanks for any advice or input!
    Mike
  2. Patrick Wong
    18,200
    6,471
    I think you should clean the throttle body interior and throttle plate without "tearing the throttle body apart". Use the minimum amount of throttle body cleaner as you do not want fluid carrying dirt to drip down the throttle motor shaft.
