P0A08 error code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by whodat, Sep 13, 2010.
  1. whodat
    whodat Member
    117
    Aptos, CA
    Previous thread (with new subject title) on my 06 Prius losing steering and brakes while driving with multiple errors (red triangle, battery, etc.) while braking on steep down hill section of hwy 17 (mountain road). Took car to dealer but dealer could not find the root cause.
    Print out from dealer:
    131297 found code P0A08. dc/dc converter status circuit. checked aux battery-passed load test. Check cable connection from auxiliary battery terminal - cables connections are secure. Checked inverter water pump coolant level and operation-pump is working.
    So I had them replace the 12V aux battery. So far no relapse of this problem with one day driving with the new 12V aux battery. I am not convinced that this is the root cause.
    Galaxee and Patrick Wong had previous threads something about DC/DC converters overheating when the inverter pumps failed - and perhaps that is closer to the root cause of the issue my 06 Prius is having.
    Thoughts?
  2. Patrick Wong
    18,200
    6,471
    I suggest that you inspect the inverter coolant pump yourself, to verify that it is working. This is easy enough to do:
    1. Make the car IG-ON (from IG-OFF, press the POWER button 2x without depressing the brake pedal.) All of the instrument panel warning lights will be on.
    2. Open the hood and look for the inverter coolant pump behind the driver's side headlamp. Listen for the sound of the pump running (should sound like an aquarium pump and you should not hear air bubbles.)
    3. Look at the inverter coolant reservoir and note turbulence in the fluid which shows the fluid is circulating.
    Also note that the original 12V battery passed the "load test". This is why I suggest that owners not bother to pay for this test at the dealer, if there are any questions about the battery just replace it.
  3. whodat
    whodat Member
    117
    Aptos, CA
    I checked the hose between the driver side headlamp and the fuse box and noted some slight vibration when I put my finger on it - so I am guessing (if that's the inverter coolant pump hose) its working.
    Which coolant reservoir is the inverter coolant - the yellow fluid reservoir?
    Thanks
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
  5. gabrielino
    gabrielino New Member
    stuart
    Your car and city caught my eye.
    I just bought a 2006 Prius and I live in Aptos too. I get back there in mid may. Perhaps we can exchange some info?
    gabe
  6. kutcht1
    kutcht1 Member
    303
    82
    Andover, Minnesota
    Question for the original poster or anyone else who has had the P0A08 code. Did you also get a high pitched alarm tone?
    TomK
  7. ozmatt
    ozmatt Active Member
    601
    249
    australia
    Hi Kutch, this is a 14 year old thread so the original poster might not be around! but to answer your question YES! i get the high pitched alarm tone along with P0A08 (and others) randomly every few months, im not 100% sure but think the alarm is part of the brake master warning once the aux battery gets down to about 10 or 11v the brake system has a hissy.
    Matt
