P0a0f p3190 c1259 c1310 u0155
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Perl1947, Mar 18, 2021.
  1. Perl1947
    Perl1947 Junior Member
    46
    Israel
    Pried gen 3.
    Egr dismantled and cleaned with cooler. All coolants replaced.
    Engine start with coolant shakes forget to connect mac but now all those errors.
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,593
    5,891
    Texas Hill Country
    One suggestion, look up the codes and post the simple explanations with your question. It makes it easier and ensues us you have looked into it. Plus explain what you have tried already.
    It seems you have a fuel problem and a braking system problem. Bad gas, injectors or fuel pump come to mind. The brake actuator/pump is a known issue on these cars and in the US have a special customer support program (warranty) in many cases for ten years. Dealer must diagnose and see the codes.
  3. Perl1947
    46
    Israel
    All was fine.
    But I decided to clean the whole egr.
    After installation cooler .engine shudder.
    I forgot to. Connect maf.
    12.3 battery.
    Still engine shut down.
  4. Perl1947
    46
    Israel
    I will check the air induction?
    Remove the front wipers ?
  5. Perl1947
    46
    Israel
    Finally found that the pcv hose to inlet manifold
    Was disconnected. End of story all good.
    Tks.
    ASRDogman likes this.
  6. ChapmanF
    17,340
    Definite lean-mixture situation there. :D
  7. Mendel Leisk
    40,580
    How many miles?
