P0A11 dc/dc converter enable circuit/open help
Discussion in 'Gen 2 Prius Technical Discussion' started by Van Baggett, Dec 14, 2014.
  1. Van Baggett
    Van Baggett Junior Member
    Has anyone had this error code and know how to resolve it? Is this a battery issue? Converter?
    Thanks
    Van
  2. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    Hello Van, welcome to PC.
    I have no experience of this code, but I would think the first place to check is the 5 amp fuse at the 12 volt battery terminal block (covered by the red plastic shield). Also check the small white wire with connector is plugged into the connector block, and that the wire is not damaged. This wire, and fuse feeds the 12 volt battery charge level information to the DC/DC converter.
    John (Britprius)
    #2 Britprius, Dec 14, 2014
  3. Patrick Wong
    18,200
    6,471
    I do not believe P0A11 is a valid Prius DTC. P0A10 would point to a failed DC/DC converter within the inverter.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,369
    3,217
    Madison, Wisconsin
    I'd want a bit more background.
    How did they confirm this code?
    What are the current symptoms?
    What were the conditions and symptoms prior to this?
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    POA1's are all Hybrid Powertrain Control Module nags.
    Was the car in a front end collision?
  6. Jeremiah216
    Jeremiah216 New Member
    Cleveland Ohio
    Hi did you figure out the problem? I'm having the same problem as well
