P0A1D - HV Control - Replaced - No Ready Light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tracy ing, Dec 22, 2017.
  1. tracy ing
    tracy ing Active Member
    384
    171
    wash dc
    Hi all need some help. Car threw P0A1D indicating one of the two computers under the dash under the passenger air bag was not working. There are I think the engine computer on the left with the hybrid drive computer bolted to it on the right. Triangle of death.
    Bought a HV controller off of ebay with the same part number for 10 bucks. Installed it and threw the dash in the car as far as plugging everything up and tried and had no code anymore but still had triangle of death.
    I checked and found I had not pushed down on the HV batter orange disconnector so I did that and plugged the 12 volt battery back in and tired again.
    The triangle has gone away, the car looks like it is booting up properly, no codes are being thrown, it went into neutral one time and no more. The engine did not ever fire up even with heater on, the ready light has never come on, i stopped trying cause i read something about the immobilizer and turning the car on more than 20 times could foul things up.
    I replaced only the HV drive controller 89981-47123 not the engine ecu to its left, is this ok to do ?
    Is there some trick I still have to do to get the replacement HV Controller to work with the existing engine ECU and or immobilizer ? (like shorting those pins and leaving it on 40 minutes or whatever)
    Although there are no codes the check engine light is on
    Thanks
  2. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    Could you post pictures of the HV controller you said you replaced? Have never heard of such a controller before.
  3. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    Im not 100% sure but when you replace some computer related parts the dealer has to reset everything so they can communicate properly..even if the part numbers are the same... like the fob.. all the same part number but without programming they don't work.
  4. tracy ing
    384
    171
    wash dc
    i cant post links, go to google search for 89981-47123 and click IMAGES
    Behind the glove boxes under the dash have to remove dash there are two computers bolted together, they have to be lifted out towards the windshield. Left one is the engine ecu i think, and the right one is the hv controller, i think its for the transmission, Thats the one I replaced.
    You can see these two computers with all their plugs if you just remove your bottom glove box, it just pops out.
  5. bisco
    51,155
    welcome! how many miles on her? how is the 12v health?
  6. tracy ing
    384
    171
    wash dc
    Hybrid Powertrain Control Module
  7. tracy ing
    384
    171
    wash dc
    12 volt fine hundreds of thousands of miles
  8. JC91006
    16,673
    8,518
    Can you provide a little history of your car? How the error came about?
  9. tracy ing
    384
    171
    wash dc
    Wife was at work car would not go in gear, she sat and sat and two hours went by she got it in gear, left work early came home.
    Parked it here didnt cut it off. I cut it off put it in gear moved forward.
    Cut it off restarted would not start or go in gear threw P0A1D
    Internet said check for moisture in some connectors, that didn't work.
    Another prius came by we swapped everything in the rear of dead car to good car all tested good, battery and all the electronics in the rear.
    Code indicates there is no communications bus and if not a wiring issue the module is bad.
    Replaced the module with exact same part number 89981-47123 and on first boot up it stopped throwing the codes related to the comm bus for the transmission computer
    It still had a triangle but I traced that to the high voltage plug i pulled on the traction battery, wasn't pushed down and locked
    Press brake press ON button twice the check engine light is on with no code, triangle is off, the car icon on display is green, engine does not start and cant place in gear.
    If I move shifter to neutral AS IT BOOTS UP it may go into neutral but thats it, if I wait for full boot up it wont even go into neutral.
    The replaced module cleared the P0A1D code, so I am wondering when that is replaced (its bolted to the engine computer) does some process have to be done to allow it to synch up with the immobilizer. The engine ECU was NOT replaced, only the computer to its righjt that is for the transmission. Hybrid Powertrain Control Module
  10. bisco
    51,155
    what code reader are you using?
  11. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    271
    557
    Dallas -Fort Worth
    Here are the directions to register the the HV Control ECU with your car. If you don't do this the immobilizer will not let you READY the car. I've always used a paper clip to jumper CG and TC. Remember, your car will have to sit for 30+ minutes running only off of the 12 volt battery so if you have a charger that you can put on it for this procedure it would be a good idea.
    SFO, Beachbummm, m.wynn and 1 other person like this.
  12. Texas Hybrid Batteries
    271
    557
    Dallas -Fort Worth
    It's the one that controls the Hybrid System
    SFO and Beachbummm like this.
  13. tracy ing
    384
    171
    wash dc
    Its 3 am, I woke up after charging the battery and started doing this, then came here and saw concurrence that this is what to try. THANK YOU
    In another 15 minutes we will see if this fixed it, and if it does, Ill be in the mountains in the rain putting the dash together so my wife doesnt once again leave in my f 350 7.3 liter turbo powerstroke for a 200 mile round trip commute to work. :)
    Let me add that the pins I jumped resulted in the display going into DIAGNOSTICS MODE so I hope those were the correct pins to jump. BTW the diag mode has three categorys listed and all are green as in passed diags.
    I chose the pins by going to pin 4 on the long edge of the connector and pin 5 on the short edge starting from left looking underneath with long edge being top left
  14. tracy ing
    384
    171
    wash dc
    code reader is harbor freight
    Autel AL519 Color Screen OBDII/CAN Scan Tool Graphing DTC Look Up I/M Ready Live Data OBDII Code Scanner
    it show MIL off and no codes on any of the three modules it sees, check engine light is on
    m.wynn likes this.
  15. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    Thanks so much for this info. I do understand what it does now, and even where its located.
  16. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    That leaves 11 or more ECUs it doesn't see, one or more that has set a code.
    Autel make Prius capable readers, perhaps it needs some software updated.
    m.wynn likes this.
  17. tracy ing
    384
    171
    wash dc
    Guess what ?
    DRUMROLL
    Its working :)
    Ok so first time I tried this the battery died before I got to 30 minutes, I had a 2 6 10 amp small charger set at 6 amps and the battery could have been drained a lot from days of messing about.
    At 6 amps it would not keep up in diag mode, lost 1/100 of a volt a second, at 10 amps it gained 1/100 about every 3 seconds, so I charged it for 8 hours at 6 amps woke up set it at 10 amps and then did the pins using a paperclip for 30 minutes. Ready light is on went in gear moved forward.
    NOW TO SIT IN THE DARK RAIN IN THE MOUNTAINS AND PUT THE DASH IN
    THANKS ALL
    battery made 4-15 and is an expensive optima yellow top
  18. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    Congrats!
  19. tracy ing
    384
    171
    wash dc
    Drove 40 miles to town and back all is well THANKS
    Raytheeagle likes this.
  20. tracy ing
    384
    171
    wash dc
    OK I AM BACK. MORE PROBLEMS
    So replacing the Hybrid Powertrain Control Module worked for about 6 weeks and thousands of miles, I ended up also replacing the 12 vot battery too last week
    Drove the car last night, parked it, today, its dead again with a new but related code,
    U0293 Lost Communication With Hybrid Powertrain Control Module
    When the car is powered up, ready light never comes on, no triangle is lit, and all of the shift indicators start blinking and the engine fan is on.
    I have three HPCM tried all of them none did anything to alter the symptoms
    When I use my code reader I used to see three different "things" I could talk to to try and pull codes from and I would have to select each one and check for codes., I no longer am offered a choice and am taken straight into the screen where I can choose to read a code.
