P0A4C & P0A4D - ICE shut down at about 70 mph
Discussion in 'Gen 2 Prius Technical Discussion' started by Mattp, Apr 11, 2021.
  1. Mattp
    Mattp New Member
    Fort Worth, TX
    The issue...
    Red Triangle and all the warning lights
    The car
    2009 Prius - 230,000 miles
    When I hit about 70mph on the highway the ICE completely shuts off leaving me to coast off the hybrid battery. If I pull over and turn the car off wait about 30 seconds the car comes on and will operate on the ICE for a short burst then back to battery. I can use this to get off the highway.
    Once off the highway and taking normal residential like streets (anything below 60mph) the car will operate like normal. The ICE and hybrid system will operate in tandem just like you would expect. During this time the warning lights stay active.
    First time it happened after the car sat over night it was fine the next morning with zero warning lights. On the way to work after about 20 miles it triggered off and I had been going 70+mph for about 10 miles. Let it sit all day and work and the lights are off again. Then on the drive home after only a little bit of driving at 70+ it lit everything up and shut off the ICE (I should state that every time the warnings pop that the ICE shuts off). Limped home via backroads under 70 and never had an issue but the warnings were still on.
    I've heard the hybrid battery fan kick on the first 2 times this happened, but not this last time. This is because I did see my inverter pump had hardly any flow in the tank. Swapped it out and had a dude. Swapped in another and now that tank has tons of movement. I've pulled the codes P0A4C & P0A4D.
    Looked at the wires behind the glove box and they look fine. Can't see any issues with the little connectors on the side of the transaxle. But the issue still surfaced again today after I went ahead and swapped the battery with a new one. The old one had a production date from 2012.
    Todays event I was watching the info screen. Battery had 2 bars as I entered the highway. Hit 70mph and off went the ICE, just at the end of the on ramp. Immediately plugged in the scanner and found only my trusty old P0A4C & D codes. Limped off the highway via stopping, turning off entire car, waiting 30 seconds, turning back on so that the ICE was alive, driving about .5 miles before ICE shuts down, and repeat. Once on the access road and road home (about another 7 or 8 miles) the car ran fine never once killing the ICE. But again Triangle and check engine stayed on the entire time. Oh and the hybrid fan never kicked on during this issue today.
    So my issue is that the ICE will shut off at highway speeds but seems perfectly fine cruising around doing little around town tasks. I've done the inverter pump, I've visually inspected the wires, and I've cussed the gods. My fear is that it is the hybrid generator, but nothing I can pull up says "oh yeah btw the ICE will shut down with this issue". Would love to have help with this please.
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  3. T1 Terry
    T1 Terry Active Member
    929
    491
    My guess is either a blocked fuel tank breather or a blocked fuel filter. My Australian built 2008 Gen 2 suffered from a blocked catalytic converter and it turned out a blocked fuel filter was causing it to run lean and this lean run cleaned the carbon build up out of the exhaust before the Cat and blocked it. Fortunately here in Australia, you can buy an after market Cat for $120 and the fuel filter is under the body between the fuel tank and the ICE so easy to swap out for a new unit. Now the 2008 Prius goes like a rocket again, even though it has 730,000km on the clock.
    Worth doing a fuel flow test, unfortunately I know nothing about how the US model Prius powers their fuel pump so I can tell you how to just power up the pump so you can measure the fuel delivery over 1 min, how many ltrs, well USgal i guess for a US production model.
    T1 Terry
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    This is a bit unusual. Perhaps you're having some engine power issues? While you're rolling along at speed, is the battery recharging or is it depleting further?
  5. ChapmanF
    18,547
    I would definitely go through the workup for the codes you have, as posted by SFO.
    The generator resolver is a critical component that tells the HV ECU the rotating position of the MG1 rotor to 1/4096th of a revolution at all times, which information the ECU needs so it can properly shape the electric waveforms to/from MG1's coils. If it can't trust that signal it can't control MG1. If it can't control MG1 it has no way to make use of power from the engine. I don't think it would be time well spent here to be looking in other directions than where the codes point.
    The resolver itself is the only part of the resolver circuit that's inside the transaxle, but it is such a simple device there's hardly any way for it to be bad. The issue is probably something else fairly simple and repairable,
    strawbrad likes this.
  6. Mattp
    Mattp New Member
    Fort Worth, TX
    The scanner I used was a - INNOVA 5310
    I've kind of looked at the wiring in those instructions. The wires on the HV ECU behind the glove box all looked good. Pulled the top plugs and inspected it for any defect, looked perfect. As for the 3 plugs on the transaxle, I've only visually check the top to by the water pump, which looked ok on the wires. I'll get the jack out and look at the one above the drain plug this weekend.
    As for what the battery is doing once the engine shuts off. While trying to stay with traffic to get to a safe spot to pull over the battery drains down. But if I get a chance to coast or brake the battery does show that it is getting a receiving charge, via the HUD.
    While on roads below 50mph the car operate exactly as it should.
    But my real question as someone who has always worked on my own cars since I was 15 is this... WHY would the hybrid system shut down the ICE, if the problem (based on the codes pulled) is based in the hybrid/electric system? This feels kind of counter intuitive as the codes say issue with hybrid parts, but the computer says ok kill the ICE and lets keep operating the part we have an issue with.
    Thanks for the additional ideas. The fuel filter would make sense as a lean out issue at higher speeds thus killing the ICE.
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,088
    1,997
    NJ-USA
    The synergy drive system MUST have proper function of MG1 in order to do anything with the ICE. So if there is any glitch with the MG1 resolver, it can't use it to charge or transfer torque to the wheels etc- so shut down is the safest option. You might be able to keep MG2 going a bit until the HV pack is run down (as a "get out of the middle of the intersection" option).
    I suspect you have an intermittant open circuit in the wiring at or near the transmission connector. For your problem I suggest unplugging the hybrid ecu connector (for the harness to the transmission), then back probe two of the wires for one of the resolver coils and measure resistance- watch (or listen if your meter has an audible continuity function) while gently wiggling the harness at the trans and its connectors. Repeat for the other two coils.
  8. Figster10
    Figster10 Member
    207
    61
    Sacramento
    Hey I'm currently having the same issues with my car. 2005 prius 200k or more since not true mileage. I work on a lot of hybrid batteries as a side gig and have installed 3(three) batteries reconditioned. I am going to see about messing with the 12v and getting another hyrbid battery from another car to rule that out. If I coast 45 mph I notice know problems as well. When I drive 20 miles on the freeway it runs almost like quietly going limp and the charge drops to 2 bars struggling to get back up. I work on these gen 2 a lot but this one is weird. I have techstream just need to see what exactly to do first.
    Issues: drives fine on roads, struggles after 10 miles on freeway. Abs, vsc, Triangle turns on and I ride through it until eventually car dies out and after I let it sit and delete codes it turns on and I have to coast it back like nothing happened.
    Codes that pop up are u0100, u0111 lost control with ecm/pcm, lost communication with battery energy
    Live diagnostic readings show all leveled cell readings on hybrid battery.
    talk to me, folks.
    I'm hearing clogged fuel filter, possible 12v battery connection/voltage
  9. mr_guy_mann
    4,088
    1,997
    NJ-USA
    Connect your techstream and pull up data for the engine ECM or the battery ecu then drive it to confirm what loses communication when the fault occurs. From the codes given, you have something messing up the CAN network data bus between those modules. If the engine, hybrid control and HV battery ecu's can't talk, then the car can't run at all.
    That could be an intermittant CAN wiring fault (short or open circuit, possibly a loose connection) or a module on that network could be briefly losing power or ground. You need to get wiring diagrams for your car and get REALLY good at reading and understanding them. Network comm faults can be among the most challenging problems to fix.
    A bad 12V battery or connection can cause all sorts of grief on a Prius, but I would not expect that to affect it only at higher speeds. Usually it would glitch right when you started the car.
    dolj likes this.
  10. ChapmanF
    18,547
    If you're really having "the same issues", namely the P0A4C and P0A4D in the title of this thread, then it would make sense to focus on the workup steps for those issues, which were posted upthread.
    If not, starting a different thread for the issues you are having would help avoid mixing up suggestions.
    violinguy and dolj like this.
  11. Figster10
    Figster10 Member
    207
    61
    Sacramento
    I was asking what exactly happened in your experience perhaps it could be my exact issue. Nothing more and nothing less.
  12. ChapmanF
    18,547
    What codes do you have? If they're not P0A4C and P0A4D, that rules out being the same issue.
  13. James Analytic
    360
    Michigan
    Rescue from the scrappers, with a reported ability to drive off the truck and the prior owner gave up on after working on the HV battery. Scrapper wanted the cat and let it go for another sounded like.
    Anyhow, the Prius didn't start when I got there. P0A4C and P0A4D read and as I thought I had posted prior one with a similar situation with the MG1 resolver wiring, something chewed the red wire completely open circuit. Actually, the prior one I worked on was way worse and had to splice a couple wires back. I'll see if I can dig up photos as seems like I took and thought posted on Prius chat. Anyway, Jimmy rigged this ones red wire together and cleared the two codes.
    Found a dead mouse along with the mess made after hunting down the next codes that appeared, P0343 and P0AA6. No mouse nest found inside the reported bad HV battery and no HV battery apparent isolation fault. Cleaned the mouse nests found in the trunk and wheel well. After cleaning a bit and clearing those last codes and running the engine to charge the HV battery, a P0037 and P0340 appeared. Of course, no cat, P0037 is obvious.
    Visually inspected the harness from the cam position sensor on down and another completely open circuit. Chomped right through. This is the photo after I removed the wrap on the pigtail side and slit the harness wrap to pull out the other side of the wiring for easier access to splice.
    Spliced and good to go with what was noted as a bad HV battery vehicle, to my surprise being an apparently good one for the test drive after. Another save from the crusher, shredder and energy waste manager. Next, to install the cat for her and inspect the drums brakes since emergency brake wasn't engaging. Amazing and thanks Mr Mouse.
