P0A7A code
Discussion in 'Gen 2 Prius Main Forum' started by Noahlr, Sep 1, 2018.
  1. Noahlr
    Noahlr New Member
    Iowa
    2008 with 113000 miles
    All the warning lights came on
    Lost all acceleration while driving
    Car will power up. engine runs for a few seconds and shuts off....will not shift into gear.
    Inverter pump is running as it should.
    12v Battery is new.
    Getting the POA7A CODE
    also got the P2238 CODE once but have not been able to replicate code sense.
    Not sure where to start....any advice would be greatly appreciated.
    Noah
  2. PriusCamper
    PriusCamper Senior Member
    11,233
    4,588
    Pacific Northwest, USA
    Easiest way is to Google the error codes and it'll point you to most popular threads for the repair efforts on here, in this case threads about inverter repair.
    Noahlr likes this.
  3. Noahlr
    Noahlr New Member
    Iowa
    Note.....when starting the engine runs pretty rough then shuts down.
  4. hill
    8,297
    Smog / 02 sensors
    either your cat converter died (100k mile warrany - sorry) or if your lucky, it's disconected. The other code is worse ... generator / inverter.
    Noahlr likes this.
  5. Noahlr
    Noahlr New Member
    Iowa
    Bank 1 sensors 1&2 are both good.
    Any ideas on how to test the inverter?
  6. bisco
    49,842
    inverter pump
  7. Noahlr
    Noahlr New Member
    Iowa
    Changed out the inverter with no luck....still same issue/code. Anyone have any ideas on where to start next? Not a lot of info on the web.
    How would I test the transaxle and hvcm?
  8. PriusCamper
    11,233
    4,588
    John Kelly did a milliohm meter demo video on youtube. In it he goes into some methods to diagnose a bad electric motor assembly. I suspect, even if you don't have access to one of these meters, it will at least point you in the right direction for more diagnosis:
    Patrick Wong likes this.
  9. Noahlr
    Noahlr New Member
    Iowa
  10. Noahlr
    Noahlr New Member
    Iowa
    I don't have access to a million locally. No one sells them. This is the only step via Toyota tech info that I wasn't able to complete. I'm really hoping it's not the transaxle that's causing the issue.
  11. PriusCamper
    11,233
    4,588
    They're a fairly common tool among electrical engineers that work on computer hardware. Also your local community college or university may be able to help...
  12. Ricardo Oliveira
    Ricardo Oliveira Junior Member
    san jose, california
    I have the same problem. what was the solution in your case?
