p0a7a - no dash lights, seems to drive fine
Discussion in 'Gen 2 Prius Main Forum' started by highmilesgarage, Jul 25, 2024 at 2:39 PM.
  1. highmilesgarage
    highmilesgarage Active Member
    278
    104
    Kansas City
    can you have a p0a7a with no dash lights (no check engine light) and seems to drive fine? Got a call from a friend who's trying to buy a Prius and when it's scanned it showed p0a7a only (scanner can't read sub code)
    told him can't really verify the real issue (or how bad it is) without the sub code.
    car drives fine and was wondering if there are cases where a P0a7a doesn't really trigger a check engine light or RTOD?
  2. Tombukt2
    Tombukt2 Senior Member
    9,201
    1,613
    Durham NC
    Well I imagine the car could drive fine It's just saying that there was a problem with some sort of voltage in the DC to AC converter right.
  3. ChapmanF
    15,682
    A 'permanent' code will show up on a scanner without lighting a warning light. It remains from a code that was reported as 'current' in the past and may have been fixed; the car eventually deletes 'permanent' codes if the problem is no longer seen.
    A P0A7A definitely lights both the master-warning and check-engine lights, and limits driving, if it is current.
    Brian1954 likes this.
