P0A7A - No other codes?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dubseven, Oct 24, 2018.
  1. dubseven
    dubseven Junior Member
    Denver, CO
    Hi all - 2007 Prius with a persistent P0A7A. Have replaced inverter and pump. Still getting same code. No other codes. Battery pack voltages look VERY low - any chance the pack is causing the issue? Or the HV ECU?
    Thanks!
    49,371
    maybe the pack needs charging
  3. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    There are 9 different subcodes (INFs) for that thrown DTC.
    Without knowing the supportive INF, it would be difficult to offer advice.
    You may need to source/borrow a Toyota hybrid compatible OBD2 reader to proceed any further with a diagnosis.
    Raytheeagle likes this.
