P0A80 and P3021
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cduke3173, Jul 3, 2019.
  1. Cduke3173
    Cduke3173 Junior Member
    Mississippi
    Ok I am new to this so please bear with me. I have a 2005 Gen 2 Prius 300K miles for about a year now I have been Getting the P0A80 code without any real issues but in the last month I have been getting P3021 (Low volts on pack 11). My question is if I have had a bad HV pack for the last year by getting code P0A80 why did it not tell me which pack is bad?
    Thank You for your help.
    49,429
    perhaps as the packs go out of parameters, the first code hits at a certain point in the process, and as it degrades further, the next code hits
  3. Cduke3173
    Mississippi
    Here is a screen shot of my volts as I can see my only issue is block 11
    49,429
    makes complete sense now
    Cduke3173 likes this.
  5. Cduke3173
    Mississippi
    From what I can tell my only issues is the Block 11
  6. bisco
    49,429
    that's what it looks like, was that test under load?
  7. Cduke3173
    Mississippi
    Yes it was done while driving and A/C on Here is one at idle Screenshot_20190703-154350.png
  8. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    You would only get a specific code, when one or all of the modules have gone beyond the internal resistance thresholds set by the by ECU.
    Y you were only getting the p0a80 was the modules were probably still a little bit in a better shape. If you had a code reader, you'd have seen that the p0a80 was appearing in the pending section of your code reader.
  9. Cduke3173
    Mississippi
    Thanks did not relize there was a differance if it was pending.
  10. Cduke3173
    Mississippi
    So just ordered replacment cells .
  11. bisco
    49,429
    don't forget the balancing (y)
  12. Cduke3173
    Mississippi
    And what is the best way to balance them ?
  13. bisco
    49,429
    read the balancing threads, i've never done it. there are methods for matching cells, and charge/discharge cycles. the more particular you are, the longer it will last before the next out of balance event. although, some like to just throw in the cells and take their chances. a few have gotten lucky.
    Dxta likes this.
  14. Nutsforprius
    Nutsforprius New Member
    Nebraska
    My 2007 just started with P0A80 and P3021 codes. I swapped hybrid pack with one from another car that wasn't throwing codes. Now the first car is throwing same codes with different pack and the second car is not. I have a new battery on the way. But any.ideas why one car does it but not the car
