P0A80 Battery Fix Last Month
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2011GeorgePrius, Feb 8, 2021.
  1. 2011GeorgePrius
    2011GeorgePrius Junior Member
    35
    Reisterstown Md
    P0A80 Is Here Had I Had P0AA6 Last Month. Check Hybrid System Is Back. Toyota Said Battery Is Bad Block 14 At 15.23V Others At 17VS. I Had The Dealership Fix It Under Warranty But Now Is Failing Again. Prius At 145,383, Miles 145,310 When It Was Repaired Last Month. 12V 11.93 OFF 13.92 ON.
  2. JC91006
    16,825
    8,600
    bring it back to the dealer
    SFO and Grit like this.
  3. 2011GeorgePrius
    35
    Reisterstown Md
    Is it really the hybrid battery I put in about 70 miles since last visited
  4. JC91006
    16,825
    8,600
    Whatever it may be, the dealer is willing to fix it under warranty. If they put a new battery in already, the problem maybe somewhere else. Let them sort it out for you
  5. 2011GeorgePrius
    35
    Reisterstown Md
    I’ll let them sort it out tomorrow when I drop it off again
  6. 2011GeorgePrius
    35
    Reisterstown Md
    But why would it fail in a month?
  7. JC91006
    16,825
    8,600
    It's a machine and humans are not perfect. That's why they have a warranty on their work
    jerrymildred likes this.
  8. 2011GeorgePrius
    35
    Reisterstown Md
    True I’ll let them look at it tomorrow I’ll drop it off then keep you posted
  9. JC91006
    16,825
    8,600
    It may not even be the battery that's failing, but since they are the Pros, let them tell you what the problem is
  10. 2011GeorgePrius
    35
    Reisterstown Md
    But they said block 14 isbad
  11. JC91006
    16,825
    8,600
    unless they didn't replace the battery, a new battery should not fail again in a month. So best to let them address it
  12. 2011GeorgePrius
    35
    Reisterstown Md
    It was new maybe A cell lost balance maybe? Could I recharge the cell back to 17VS
  13. JC91006
    16,825
    8,600
    You shouldn't do anything to the battery if it's new. It's very suspicious already that a new battery has failed. Let them deal with it
  14. 2011GeorgePrius
    35
    Reisterstown Md
    I’ll keep you updated
  15. Grit
    Grit Senior Member
    6,576
    4,228
    Wilkes Land
    In a perfect world, it wouldn’t fail at all. Did you actually get a new battery or a non Toyota refurb?
    A feller once got the same code as yours, he had a 2014 with 54,000 miles and swore it couldn’t be the hv battery.
  16. bisco
    52,346
    do you have extended warranty? or is maryland a 10/150 state? if the latter, they are supposed to replace the whole battery, and you would have paperwork. if the former, and they actually 'replaced a module' (most dealers won't) anothe module may have failed, and it will probably keep happening.
    you need a new 12v battery or at least a charge. it is low from not driving. any idea how old it is?
