P0A80 code briefly fixed by replacing 12v battery
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Garkinarkin, Feb 13, 2022.
  1. Garkinarkin
    Garkinarkin New Member
    TN
    So I had the P0A80 code come on, and after checking that the 12v required replacement, went on to replace it. This immediately fixed the problem, and everything went back to normal. 2 weeks of regular driving later, the code is back, and I am stumped. I checked the connections on the battery, and everything was secure. Any ideas about the cause?
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Traction battery
  3. ChapmanF
    18,546
    Changing the 12 volt battery didn't fix anything. While you had the old battery out, the computer in the car lost its memory of the trouble code. Then you didn't see the code for a while until the computer had time to figure out again what it knew before about the condition of the traction battery.
    52,390
    have you looked up the code meaning?
