P0A80 code but doesn’t give any bad cells
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by LilyWever, Sep 2, 2019.
  1. LilyWever
    LilyWever New Member
    Indiana
    I have a 2005 Prius. I drove it to work and as I was leaving the dashboard lit up with all sorts of warning lights including the dreaded red triangle. I had to leave it there for a couple of days until my boyfriend came to look at it. He drove it to autozone because he didn’t have his code reader. He turned the car off and when he came back outside, the car was completely normal again and said nothing was wrong.
    We got it back to my house and had to leave it there for a couple days. This weekend all of the lights came back on. We took out the fan, which was relatively dirty and cleaned it out. But then we test drove it, turning it off and on a couple more times, and all the lights came back on. Then two more codes popped up C1310 (malfunction in HV system) and C1241 (abnormally low or high battery positive voltage). And we turned it off a couple more times and the C1310 went away. The fact that only the replace hybrid battery comes up makes me think it’s not that the whole thing needs to be replaced. When the lights are off and it’s not showing a code, the car is fine, drives normal, and it screen shows it charging normally. When the lights are on and it’s showing a code is when it acts weird.
    52,373
    welcome!
    start with a load test of the 12v health
    check the inverter fluid reservoir for movement with the car 'ready'
    then get tech stream diagnostic software if you're gonna diy
    if the hv battery is bad, it never goes bad altogether. it's made of of modules that fail one or two at a time.
    but at your age, they will continue to fail
    you can get a prolong grid charger to restore some life, but you might be better off dropping $1,600. on a new battery
    all the best!(y)
  3. LilyWever
    Indiana
    I assumed that it was the battery, but then reading other people’s experiences, they said the code reader specifically said the certain cells were bad. The code reader only gives the replace hybrid battery. I just wasn’t sure if that really meant anything, like, if it could be something else.
    Thank you for your reply! I will try those other things this weekend!
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
  5. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    What code reader are you using to read the codes? My guess is a generic one that can’t read the Toyota specific codes. Your going to have to get a reader that can read the Toyota specific codes to progress any further.
