P0a80 code: definitely means hybrid battery is bad?
Discussion in 'Gen 2 Prius Main Forum' started by Charles2002, Oct 14, 2018.
  1. Charles2002
    Charles2002 New Member
    Long Island New York
    I have had my 2007 Prius about a year now. It has about 138k miles on it. The other day the triangle light came on. Mechanic read the code and it said P0a80. He cleared the code. I drove home (a few miles) and parked the car. Next day triangle was back as soon as I started it. I cleared it with my own scan tool. Started driving. within a few miles triangle came back on. Parked the car at my destination. When I pulled over I noticed for the first time the fan by rear passenger side seatback blowing (seemed to be on high). Never heard that sound before or even knew there was a fan there.
    My question is, does this code definitely mean the hybrid battery is bad or could there be another reason? For me it's a big decision as to whether to start spending money on this car. Are there other tests I should do before concluding that the hybrid battery is indeed bad? Any advice appreciated. Thanks.
    Other electrical things going on prior to triangle warning:
    In past month clock lost major time (hours) a few times.
    In past 4 months dashboard would sometimes "go blank," i.e. no speedometer etc
    In past 4 months sometimes car would not turn off. Took may tries to get it to turn off.
    49,583
    welcome!
    you should take it to a dealer, or someone with toyota tech stream diagnostic software to load test the modules.
    it likely is the battery, but with your low mileage, you should call toyota and ask for warranty assistance.
    the 12 volt health should be tested, the battery cooling fan cleaned and the other problems should go away.
    if not, you may need a new combo meter.
    all the best!(y)
  3. Charles2002
    Thanks Bisco!
  4. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Yes, the first thing you should check is the 12v battery voltage. Check it in the morning before you start the car and let us know what it is.
    Charles2002 likes this.
  5. Charles2002
    Had the batteries tested at Toyota. They told me the 12v battery is fine but the hybrid pack is bad. I decided to bite the bullet and get a new battery pack installed. It will be $2550 + tax. I thought about other options such as used battery or rebuilt. These options seem dicey. Now for the $2700 this car should last another 150k or 10 years.
    Skibob likes this.
