P0A80 code in my 2007 prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Richard Figueroa, Jun 18, 2020.
  1. Richard Figueroa
    Richard Figueroa Junior Member
    Hi guys, I habe the P0A80 code in my prius and I vheck the modules volt and fans and everything is working, as you see in tje picture, it say that the block 1 is low, but, all the voltages are 7.6 and up, do you thing that I have to change the sensor in the image?
    Need your advises one more time and thatnks for always be there 20200618_141440.jpeg Screenshot_20200618-140246_Torque.jpeg
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Have you checked the battery ECU connections/connectors for corrosion?
    It sounds like you may have damaged the voltage sensing harness when you removed/cleaned/reinstalled it after the recent module swap.
    Did you properly torque the module nuts to 48 inch pounds?
  3. Richard Figueroa
    I'm gonma check that, thanks
  4. Richard Figueroa
    I'm adjusting the module nuts manualy, I don't know how to put them to 48...
  5. George W
    George W Senior Member
    911
    511
    San Antonio
    Some auto parts stores have tools that you can rent or borrow. See if you can borrow a torque wrench. It needs to be set to either 48 inch pounds or four foot pounds, depending upon the type you're able to borrow
  6. bisco
    49,469
    improper torque can lead to a fire or explosion
  7. Caeasar Delacruz
    Caeasar Delacruz New Member
    Homestea fl
    Hi Richard I have the same problem Could you tell me Please How did you fix it?
