P0A80 Code On 2009
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Charles2009Prius, Jan 15, 2021.
  1. Charles2009Prius
    Charles2009Prius New Member
    Doswell VA
    Hey I’m Charles. I Have The Prius 2009 With 107,988 Miles I Had The Car Sit 16 Days The Car. I Gotten The Red Death Triangle. I’m Thinking Hybrid Battery? Battery Won’t Charge Past The Purple Bars. My Mechanic Tells Me These Codes.
    P0A0F
    P3000
    P0A80
    P0AFA
    B1421
    B1423
    12V 12.30 OFF 13.90 ON
    BB1 17.60
    BB2 17.69
    BB3 17.62
    BB4 -24.99
    BB5 -2.00
    BB6 17.56
    BB7 17.69
    BB8 17.70
    BB9 17.64
    BB10 17.75
    BB11 17.72
    BB12 15.59
    BB13 17.80
    BB14 17.40
    RR1 0.18
    RR2 0.18
    RR3 0.18
    RR4 0.18
    RR5 0.18
    RR6 0.18
    RR7 0.18
    RR8 0.18
    RR9 0.18
    RR10 0.18
    RR11 0.18
    RR12 0.18
    RR13 0.18
    RR14 0.18
    #1 Charles2009Prius, Jan 15, 2021
    49,458
    welcome!
    does your mechanic specialize in hybrids? does she have toyota techstream diagnostic software?
    it could be the battery, or it could be the 12 volt, or it could be something else
  3. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    Welcome. Besides what @bisco mentioned, it might be corrosion in the battery's wiring harness. Those negative voltages look to me like bogus readings from bad connections. BB12 looks low, too.
    You'll want to make sure your mechanic is Prius competent.
    davecook89t likes this.
  4. Charles2009Prius
    Doswell VA
    He has worked on hybrid cars before but I’m not sure if he ever done prius battery but he has Toyota software techstream
    bisco and jerrymildred like this.
  5. bisco
    49,458
    that should give him the module voltages under load, and any that are outside parameters
    Charles2009Prius likes this.
  6. Charles2009Prius
    Doswell VA
    Any options on battery? Is the 17V ok for battery and is Resistance 18 ok for battery I heard from my mechanic guy 12v must be 12.49v off and 13.89V On or higher for car to run the computers is that true?
  7. jerrymildred
    11,508
    14,110
    Tampa, FL
    Those 17 V numbers are for the traction battery. The 12V numbers you give here are for the Aux 12V battery. They are totally different batteries with totally different purposes, locations, chemistries, and voltages.
    Not true at all. Even if the 12V gets down under 11V it should still power up. My brake pump was running for an unusually long time on my 2005 several years ago. It was the only symptom that my 12V was down to about 10 volts.
    And the "13.89" when on isn't measuring the battery. It's measuring the output of the DC/DC converter that's charging the 12V battery.
    It's true that a low 12V can throw codes due to insufficient voltage to the ECUs and sensors, but 12.5V in the morning is not unusual at all. If there's any doubt, put it on a charger overnight and read the codes again.
  8. Charles2009Prius
    Doswell VA
    Ok so where can I get my hybrid battery worked at? Again my 12v was at 12.30 OFF 13.90 ON and I know my hybrid battery was at 17v is it ok for that? Is what I’m asking. My Resistance was at 0.18. I have a weak cell and a I think a wiring problem you said for two other cells.
    #8 Charles2009Prius, Jan 17, 2021
  9. AzusaPrius
    AzusaPrius Senior Member
    1,875
    822
    Since you have all the codes written down, just reset and clear the codes.
    Then drive car around for a good drive. Go down hills if you can and lightly keep your foot on the brake.
    Use the brake pedal more than gliding to a stop.
    That should charge the hybrid battery back up and if it throws codes again check them and you may have to replace some cell modules.
    Check ebay out, you can find them for like $25 each.
