P0A80 code when weather is hot and no error when weather is cold.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Eshwar, Oct 28, 2018.
  1. Eshwar
    Eshwar Junior Member
    Tampa, FL
    Four Touring
    Have an odd issue going on with my 2007 Prius. Last year had batter issue for which I changed a module and battery was working fine. After one year Prius started throwing the battery error code but do not see any issue with battery i.e. I do no see battery heating up or dropping quickly. But when weather in area is down all error codes wipe automatically. Is there anything I can check for this odd issue.
  2. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    How many miles do you currently have?
    How are you reading the OBD2 codes?
    Did you clean up the HV battery fan?
    Did you balance/recondition the HV battery after swapping modules?
    davecook89t and Raytheeagle like this.
  3. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    Get a techstream to troubleshoot em
  4. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    So the BCM (battery control module) has software that (simplified) compares module voltage to measured temperature. This brings up the possibility that there is either another bad module (or two, three...) or the temperature is not correct. Temperature in FL can be because the car is not venting or the batteries are getting that hot. High battery temps are indicative of (a) failed module(s), presuming the blower fan is working correctly. It is also possible that the BCM is seeing temperatures that are not accurate and that would be a devil to determine w/o TechStream.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    You need to check the individual modules again.
    HIGHLY likely that another one is failing.
    This will continue with some regularity until you get all of them replaced.
