P0A80 - Dead Battery Three Questions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by edstark, May 4, 2011.
  1. edstark
    edstark New Member
    My 2005 Prius has a 133K miles and hasn't had any repairs until two weeks ago. I got a check engine light, then replaced a coolant flow sensor. Two hours after repair I got another check engine light and the throttle body was cleaned. Last weekend I got in my car and got a "triangle of death", a check engine light, (!), and VSC indicator. I took it to the dealer and they said I had a P0A80 error code and that one of the cells was low (I don't know if they actually tested this or just said it was). The recommendation was a new battery pack for $3000.
    I did check the (original) AUX Battery using the on screen voltage display. It did show 12.5 volts after the car sat for two hours and similar after it was driven for 20 min. Turning lights, rear defroster, and fan changed it to 11.9V. Turning the car on increased the voltage to 14.1V.
    My dealer said the order was on a long back order (87 backordered at Toyota) and said it would be ok to drive until then. Driving so far seems ok with some hesitations, especially starting from a stoplight. The battery seems to be charging and discharging normally. Gas milage is similar to before. The one thing really different is that the battery exhaust fan turns one within 15 seconds of turning the car on -- the fan is blowing cool air.
    So my first question is is it really wise to put a rebuilt battery in knowing that it has already had a significant part of it's life used? I would assume a new battery would last another 133K miles or so. I would just assume pay full price for a battery that will last that long vs save 30% and have a rebuilt one go out in a couple years.
    The second question is what are the implications of driving the car in this state? Will it somehow cause other problems or leave me stranded? I am concerned because it may be many weeks before the new battery is shipped.
    Ok, on more question... Is there something else I should be doing to troubleshoot this issue or does it seem like I should just accept that its a dead battery? Can I (should I) test the voltage of the individual cells? Does it matter?
    Thanks for your advice.
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Have you looked into purchasing from other sources such as reinvolt and there are others? Hal
  3. edstark
    edstark New Member
    to reinvolt in SC. 13 Hour drive would make this a three day trip. The cost was $2000. For $900 more I can have a new battery that (I assume) would have a significantly longer life and less hassle. What do you think about the rest?
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    This is one reason why it is helpful to post your location. There are many options beyond paying your dealer a princely sum. Reinvolt does have installers across the country. They are also not the only ones that refurbish traction batteries. You can also have a salvage battery installed. Just try to find one that has not been sitting at a junkyard for too long. Many will have some sort of warranty.
    The new battery from Toyota only has a 1 year warranty as well.
    Failure at 133K is abnormal. We have been trying to figure out the lifespan of the Gen II battery. Max seems to be 400,000 miles, so typical might be 200K - 250K. You can test/replace individual modules, if you feel comfortable taking apart the case. It usually is just 1 module out of the 28 that goes bad.
  5. Patrick Wong
    18,200
    6,493
    If this happened to me, I would first look for a traction battery from a low-mileage, recent vintage salvage donor 2G Prius, expecting to pay around $600 plus shipping. Then I would install the battery myself.
    I question the relative value of the "rebuilt" 2G alternative vs. buying a recent-vintage salvage battery.
    In order for you to test the voltage of the individual modules, if you don't have Techstream Lite or its equivalent available, you would need to open up the traction battery case for access to the modules. If you are capable of doing that then you should be able to DIY replace the battery. If you see the traction battery state-of-charge gauge rapidly moving up and down, that is a good clue that the battery has a problem.
    If the traction battery should deteriorate further then there is some possibility that it will fail to start the car and you will be stranded.
  6. edstark
    edstark New Member
    FYI I am located in St Louis, so anywhere in Missouri would be good or even Chicago since it's only about 4 hours away...
  7. seilerts
    3,326
    1,517
    38
    Santa Fe, NM
    There's a junkyard close to you, XVipers, Inc.
    They are expensive, but have a Prius specialty.
  8. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You should also consider AutoBeYours in Indianapolis. Steve will fix it for you at a reasonable price.
    I recently had my dealer install a Re-InVolt battery for $1475 plus $125 shipping to my CT dealer who installed it for under $400.
    A battery that is refurbished by a knowledgeable shop will be almost as good as a new battery. The battery modules will have been rebalanced so that all 6 cells are at the same SOC and all of the modules are checked to have matching capacity and SOC level. A good refurb shop (like Re-InVolt) will only use modules salvaged from a low mileage Prius.
    JeffD
  9. edstark
    edstark New Member
    So yesterday afternoon I found out about XVipers and they had a battery from an '09 Prius for $900. They said that they would install it at no charge. You may be able to squeak by with a salvage battery a bit cheaper, but these guys really seem to know the Prius well and have great quality parts. They are a high end salvage yard more or less in the middle of nowhere. I am really happy about the result. I am even getting about 10-15% better milage. My old battery must've been a dud overall.
    One thing I find funny is that the Toyota dealership charges four hours for a battery swap. The single person who did the swap, took just under an hour with several interuptions from customers. Overall I think it took him just over 30 minutes to change! Obviously these guys do more battery swaps than the dealership, but the dealerships charge for eight times the time it took!
    Thanks XVipers.
  10. seilerts
    3,326
    1,517
    38
    Santa Fe, NM
    Sounds like a happy ending. Thanks for sharing that bit about XVipers. One of the main problems with the hybrid battery swap is actually finding someone to do it, even though it is not that hard.
  11. Patrick Wong
    18,200
    6,493
    A new battery will include the sheet metal case, the 28 battery modules, and the busbars which connect the modules. The other parts (such as the three system main relays and the traction battery ECU) have to be moved from the old to the new battery. That is one reason why dealer labor time will be higher, but I agree that it does not need to be 4x greater.
  12. UKCLASSICPRIUS
    127
    UK LONDON
    After having replaced my transaxal, & getting my car running, Its come up with this error aswell:
    p0a80 replace hybrid battery pack...
    (I had modules sitting here, from when I rebuilt my classic with the 2g cells)
    & am fermiliar with taking out putiing in these hv batteries...
    SO I whipped of the cover & saw that all the cells were around 8 volts except for one single cell in the center of the pack (that looked a bit swolen already before I even tried working out anything), once checked that cell was just under 7 volts, which must have bought up the error..
    SO I then replaced with that cell (only) with another prismatic cell that was holding over 7v...
    IT lasted just over 2 days, before its given the same error again...
    I have not taken it apart again, BUT can see my self taking it apart again & inspecting again which cells to blame...
    Worst come to worst I will buy another used battery with warranty BUT mileage is 115k & my cars ok otherwise...
    I should be able to sort it out with the cells I have spare, But just curious as to what other symptoms are thier & common fixes aretaking place....
    Now I am seeing MANY gen2 HV failiures, before it was just the classic, with these issues..
  13. jdenenberg
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You need to use a balancing charger (e.g. Supermate DC6, about $35 per unit including the 5a 12 supply) to re-balance the cells in your modules. It does take a while per module so consider buying multiple units to speed up the process. Then all of the modules should be charged or discharged to the same voltage before reinstalling them in the HV battery.
    JeffD
    3 people like this.
  14. seilerts
    3,326
    1,517
    38
    Santa Fe, NM
    The problem is that the pack is managed by pairs. If you have one bad module, then you can get away with replacing it and its mate with a matched pair. Otherwise, you will have one partly charged, and one fully charged module, and the car will overdischarge the one while overcharging the other. To speed things up, try replacing your bad one, and its mate, with two sitting on your shelf with the both highest and most closely matched voltages. For example, if you have one that says 7.71V, and another that is 7.73V, that will probably work.
    3 people like this.
  15. UKCLASSICPRIUS
    127
    UK LONDON
    I am going to open it up, probably on wednesday, as working until then...
    I have pairs sitting here holding thier charge above 7 volts..
    I also have chargers (supernova rc charger) & many more with delta peak I have used before to charge, BUT not so much disharge..
    I have so many modules I may aswell...
    On the other hand I am being offered a CHEAP battery with 1 month warranty, I may aswell get it, & this will allow me more time for testing the other out properly... (without rush)
    I even still have a nhw20 case & ecu somewhere from my nhw11 gen2 cells rebuild...
  16. Rxmxsh
    Rxmxsh Member
    339
    Fort Worth, Tx
    I thought warranty covered 150k miles. Am I wrong?
  17. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    The warranty for the HV battery is very generous in CA and CARB states. Some of the posters in this thread w/failures aren't in such areas.
    The warranty in non-CARB states is 8 years/100K miles. I don't know about other parts of the world, but I hear the HV battery warranty because of CARB is the most generous worldwide.
    2 people like this.
