P0A80! diy charger and discharger
Discussion in 'Prius c Main Forum' started by luis morales, Jul 5, 2024 at 2:52 PM.
  1. luis morales
    luis morales Junior Member
    los angeles
    ok doing all the research!
    step 1 : run dr prius
    step 2 : run torque pro
    step 3: remove battery
    step 4: replace bad cells (if any), clean bus and nuts, clean cells and surrroundings and rotate cells (cells in middle go towards outside and the outside cells go in the middle. then assemble it back together
    step 5: charge , discharge, charge, discharge, charge.
    step 6: install battery.
    step 7: run dr prius
    step 8 run torque pro
    i know poeple made DIY chargers and dischargers for insights and prius's but cant find one for prius c! please help!!
