P0A80, help needed
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Bigguy, Aug 14, 2021.
  1. Bigguy
    Bigguy New Member
    Jamaica
    Good day everyone. I live in Jamaica and own a hybrid vehicle imported from Japan. It's called a Toyota Noah and has a 1.8l engine. It has 85000+ km on the clock but don't think that's the actual mileage one the vehicle.
    I've own it for a year and a half and decided to install an 400w amplifier. Two days after the install I was cleaning up the vehicle while playing some music with the vehicle on. Got back in the vehicle and saw four lights on on the dash, namely the triangle, the check engine and two other which seem tire related. Did a scan with a low level Launch reader and got the P0A80. Cleared it. What keeps happening now is the when moving from a stop the vehicle has a hesitation and a shudder then everything comes back in the dash.
    I know this is a Prius chairwoman but figure the tech is the same on all toyota hybrids. Any recommendations before I plunge into that massive 3xp3nse of replacing the hybrid battery?
    49,500
    welcome!
    try disconnecting the amp
  3. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    turn it up............
  4. royrose
    royrose Senior Member
    1,389
    949
    Foot of Pikes Peak
    If you disconnect the 12V battery, wait a bit, then reconnect it, that should clear the lights. You could then either wait and see if the lights come on or you could try disconnecting the amp first and see what happens.
    I would definitely not consider replacing the battery until you check the battery health.
    My suggestion is to get a bluetooth enabled OBDII adapter that plugs into the diagnostic port under the dash, then run the Dr Prius App that will give you information about the battery modules, and over all battery health. It would also tell you if there are any fault codes that would give you info about what, if anything is wrong.
    Dr Prius app info:
    Hybrid battery diagnostic and repair tool for Toyota and Lexus
  5. Bigguy
    Bigguy New Member
    Jamaica
    I removed the entire system.
  6. Bigguy
    Bigguy New Member
    Jamaica
    I've pretty much been doing the disconnect of the battery and the lights come back the same day or the next.
    Will definitely look into getting a Bluetooth adapter. Any recommendations?
  7. royrose
    1,389
    949
    Foot of Pikes Peak
    I have the OBDLink LX which Hybrid Assistant recommends. It works well on all apps that I have tried. The much cheaper Panlong is now recommended by Dr. Prius. Both work with Android phones. Check the Dr Prius site for Iphone recommendations:
    fotomoto likes this.
  8. Tim Jones
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    You either need a a new traction battery or a new inverter.
  9. Bigguy
    Bigguy New Member
    Jamaica
    That sounds real serious now and requiring a me to break the bank.
  10. ChapmanF
    15,648
    Seeing that P0A80 is the code for "replace hybrid battery pack" and is not the code for "replace inverter", I think I can guess which one of those two you're more likely to need.
  11. Tim Jones
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Ok... I was out on my Goldwing and didn't look it up but I knew it was one of the two.
    newpriusbatteries.com
    And I have replaced both items.
