P0A80 Help/Suggestions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by iskoos, Oct 5, 2019.
  1. iskoos
    iskoos Active Member
    403
    251
    Orlando, FL
    Helping a friend with 2010 Prius III (Gen 3). He got 155kmiles on it and he got the P0A80 in past July. I told him that it could be a battery module going bad. We resetted the code and he drove the vehicle. In a few months, the code appeared. I offered my help and we removed the battery cover to check each of the 28 module voltages. All voltages ranged between 8.11 and 8.21volts. This wasn't what I expected to see.
    I didn't settle with that and I load tested all of the individual modules. I ran a 12 volt electric starter motor for about 5-10 seconds continues on each module and all modules showed between 7.9 and 8.0volts which is perfectly fine. There was no module losing voltage under load.
    I went to run his car and watched the MFD and realized something weird. The car was NOT charging the battery all the time. This happened even when there was just 2 bars showing in he display. The car was at "P"
    I waited for several minutes and then it started charging for a few minutes and then stopped again.
    Mine doesn't do this. It charges almost all the time if the gas engine is running or it shuts off the gas engine.
    He also told me that while driving he realized his Gas engine is constantly on (never shuts off as it used to)
    So he has a different issue. Most likely related to the charging circuit. I checked the inverter coolant. It was slightly below "Low" I will fill it up now but I doubt it is the problem.
    What else could this be? Any ideas would be greatly appreciated.
    Thanks
  2. iskoos
    403
    251
    Orlando, FL
    Another observation (if it may help), a pump (that sits behind the inverter coolant reservoir) keeps running every 2 to 3 minutes for about 5-6 times every time the driver's door opens. It may be the brake booster pump (same sound) but mine does it one once and stops. On his car, I hear it more than several times.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    The pump in the back is the brake booster;).
    When you popped the top on the hv battery, how did the bus bars look:whistle:?
    Do you have Techstream, if not this could be one rabbit hole after another:cool:.
    I’d get the codes read so you know what it could be for more pinpointed success(y).
    SFO, iskoos and TMR-JWAP like this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    ray nailed it.
    Until you get a chance to look at the freeze frame data related to the P0A80, you're just guessing. A real friend would take his own battery and install it in his friends car to see if the problems all go away.....:LOL:
    iskoos and Raytheeagle like this.
  5. iskoos
    403
    251
    Orlando, FL
    Yes, I kind of guessed that after posting it. The same sound. The only difference as I mentioned above, mine runs for 5-6 seconds and stops. His car (after the initial 5-6 second run) keeps repeating this for 5-6 times at every 10 seconds (each boost lasts for a second or two). Mine doesn't do that. But that is a brake related issue. Shouldn't have anything to do with this.
    I put his car together, topped off the fluids (about a cup for Inverter coolant and maybe 2 cups for the radiator coolant). Took it to a test drive. The car performed just fine. It was charging the batteries when the engine was running (It was NOT chaging in the morning.) But it always start like that. I am sure the P0A80 will show up in a week or two.
    I do not have the Techstream but I do have some generic OBDII readers. It won't provide a valuable Freeze Frame data. There was no code present when I scanned it (we cleared the P0A80 a few weeks ago). After the scan, P0A80 was showing as "Pending". So it was a matter of time for it to show up.
    Would Torque Pro (paid version) or Dr. Prius (Paid version) help in anyway to diagnose the issue?
  6. iskoos
    403
    251
    Orlando, FL
    Man, I wanna make you my Real friend and come visit you if I ever get this code on my Prius.
    How about that?:)
    Raytheeagle likes this.
  7. iskoos
    403
    251
    Orlando, FL
    So, no suggestion on this what so ever?
    Anything?
  8. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    What did the wiring and bus bars look like on the modules:whistle:?
    The P0A80 code is a main code that will have causes (and many of them):cool:.
    If you think in a week or 2 the code will return, I’d buy now and have the J2534 protocol harness with Techstream ready;).
    Here’s a setup for sale :
    VCX Nano
    Good luck and keep us posted (y)
    SFO likes this.
  9. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Well, I do have spare battery packs on the shelf, along with TechStream. I have no problem connecting up to someone's car so they can see what's actually going on. I also do it to every car prior to performing any work on it. I do it to every potential purchase. It's a great tool and prevents any secrets.
    The battery is probably in very early stages of failure. You need to be able to see the freezeframe data to isolate the actual cause, or bite the bullet and do as the code says...replace the whole battery.
    Personally, my advice is to get techstream so you can get some live, real time data and freezeframe data when the fault occurs.. Or swap battery packs and see if the problem follows, which I'm confident it will.
    Your other option is to get an app like hybrid assistant/hybrid reporter. It would let you test the HV battery by running the AC system. It will graph each block voltage.
    The best way to test is to warm up the car by going for a 10 minute drive first, so the engine will stay off. Start the test on the app, fireup the AC on full blast to start draining the HV battery. Stop the test as soon as the engine starts. Use Hybrid Reporter. It will make a report for the info, including a graph of all 14 block voltages. You'll be able to see if a module is an outlier. Sometimes it's not obvious until the battery drains down a bit, then the weak module makes itself clear.
    See this thread post #5. It shows a similar situation. It took about 5 minutes under load for that module to take a dive. Although you can see it's slightly lower than the others much earlier, it's probably not as obvious when not graphed right next to the other 13 modules.
    Just Another HV Battery Thread and Experiments | PriusChat
    #9 TMR-JWAP, Oct 6, 2019
    SFO likes this.
  10. iskoos
    403
    251
    Orlando, FL
    Hi Ray, my apologies. I forgot to answer your question earlier. The both bus bars were looking fine. I didn't remove any of them. Some occasional green stuff on several modules but overall they were fine. We used a plastic brush to clean them.
    I didn't remove the battery pack from the car. I did everything while the pack is on the car (the orange breaker was out obviously).
    I will talk to him about your recommendation. Between you and TMR-JWAP, it seems you guys still focusing on the battery module.
  11. iskoos
    403
    251
    Orlando, FL
    Man, thanks for the valuable info above. Both of you recommending the Techstream. I will give that a serious look for sure.
    I started to think that I should repeat the test when the battery modules are at low voltage. When I did the test, all modules measured over 8volts. Maybe they would have behaved differently if they were at the low end.
    Also I may think about using higher-amp load. Like 5amp continues load.
    I will also check those Hybrid Assistant/Hybrid Reporter app as well. I was so sure that the most helpful app on the market for Prius is Dr. Prius so far. I guess I was wrong.
  12. iskoos
    403
    251
    Orlando, FL
    And as always, I will absolutely report back with every little update. That's what I always do...(y)
