P0A80 undocumented code
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ifty1989, Feb 19, 2020.
  1. ifty1989
    ifty1989 Junior Member
    england
    2014 Prius c
    Excel
    I have a 2014 Toyota prius every so.often the engine management light the triangle and traction light comes on.
    2 weeks ago the light came on with the same code but replace hybrid assembly.
    So I taken the battery out checked all cell individually. They were all reading between 7.0-7.4... but did see the buster bars corroded. Which I've cleaned up and put back together.
    Last night whilst driving the light came back on but now its giving the same code but undocumented code.
    Has anyone has had this code before?? Or anyone knows what this code actually means? I've checked on line but nothing comes up.
  2. Grit
    Grit Senior Member
    6,141
    4,054
    Wilkes Land
    Check if your car’s hybrid warranty is still effective, if so that code means you hit the hybrid battery lotto.
    mikey_t likes this.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    There is almost always a subcode registered along with P0A80. What's your subcode?
  4. ifty1989
    england
    2014 Prius c
    Excel
    No longer under warranty
  5. ifty1989
    england
    2014 Prius c
    Excel
    Sent in a pic that the only thing that's coming up on my diagnostic machine IMG-20200220-WA0000.jpeg
  6. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Raytheeagle likes this.
  7. ifty1989
    england
    2014 Prius c
    Excel
    Is that the wrong diagnostic tool? Using a snap on
    What would u recommend?
  8. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    ToyotaTechstream
  9. ChapmanF
    15,459
    Well, the OP already has the code, P0A80. The only issue is that particular tool doesn't have the one-liner fortune cookie for that code programmed in, so it says "undocumented code" instead. But that's no big deal, because in general you don't want to make repair decisions based on the one-liner fortune cookie programmed into your scan tool anyway.
    As for the P0A80 code, it's well documented. There's a workup section a few pages long for it in the Repair Manual (more info), and it gets discussed endlessly on PriusChat. I'm not even sure how to check online and have nothing come up. Are you sure the zeros were zeros, not ohs?
    I bet you'd get some results even with ohs.
    Techstream will still be useful, not because you need it to get the code, but you can use it to get other measurements that will help plan what to do.
    jerrymildred likes this.
  10. Mendel Leisk
    38,649
    That's quite a spread?
    Prodigyplace likes this.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Meh, not terrible;).
    It isn't a problem until it's greater than 1.2 volts:cool:.
    Then it's time to option sort(y).
    Grit and Mendel Leisk like this.
  12. bisco
    49,384
    how many miles on her?
  13. ifty1989
    england
    2014 Prius c
    Excel
    It's got 110.000 miles on it. Taken it to toyota dealer who can find a fault with the car.
    Now when I clear the codes and it's running on hybrid that's when it jerks like mad. The light appears but then just the engine runs and then I don't get any jerking at all. So its summa to do with the hybrid system but no idea where you start off from??
    Anyone else experienced this before?
  14. bisco
    49,384
    it doesn't make sense that you got the bad battery code with your scanner, and toyota gets nothing.
    was there any corossion inside the battery case or wiring harness pins?
  15. ifty1989
    england
    2014 Prius c
    Excel
    The buster bars were corroded so had them all cleaned when I took the battery out
  16. bisco
    49,384
    do you know the cars history?
  17. ifty1989
    england
    2014 Prius c
    Excel
    The car is an Import from.japan I'm the o fly owner since its arrived in UK
  18. TMR-JWAP
    TMR-JWAP Senior Member
    6,193
    5,891
    Columbia, SC
    The 7.0 to 7.4 spread is not the problem. The 7.0 is a problem. NO NiMH module in a battery pack should ever be that low. A healthy, 6 cell module will always be above 7.2 volts unless it has been almost completely discharged. Even then, it will try to "bounce back" to the 7.2 range.
    Even 7.4 is pretty low for a battery pack that has recently been removed from a car for testing. I have core packs that have been in the shop over a year that still show 7.6 or better on module voltages.
