P0A90 and P0335 codes please help diagnosing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by daley, Dec 9, 2020.
  1. daley
    daley Junior Member
    60
    Knoxville
    Hi there,
    I had another thread but hoping for help more specific to codes above.
    My 08 Prius 251k miles died on the road, it will go into ready mode but makes a whirring noise but no engine start.
    I am waiting on tech stream coming but managed to pull the 2 codes in title with scangauge and also phon we app.
    I am thinking it is a failed transaxle and or inverter problem but I want to rule out faulty a crank sensor and or wiring before deciding to put a new transaxle/ICE in the car.
    I found this posting about testing crankshaft sensor and wanted to see what folks thoughts on my findings were.
    I put car in neutral and I was able to turn the crank no problem by hand.
    I took the crankshaft sensor out and found it measures resistance of 1600ohm, I believe this to be within spec but it did look old and dirty, I have a new one on order. the connector had a lot of oil/dirt on it so I wondered if it’s not working.
    Following the above link I tested the connector and most of the tests came back within the specs.
    Here is where I am a little confused though.
    It states to test disconnect the sensor and E4, then measure each point of the harness to ground, when I do this with connectors disconnected all I get is OL, which makes sense to me but is not what the test reads as things should be.
    When I connect the E4 plug back in and measure the points at the crank sensor connector tI get 91kohms at connector 1 to ground and 0.9ohms at connector 2 to ground.
    Does any of this seem out?
    When I re connect the sensor and measure across the points at e4 connector I get 1600ohms, to me it looks like harness and sensor are functioning, can anyone see anything that says otherwise?
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  3. daley
    daley Junior Member
    60
    Knoxville
    I finally got tech steam up and running. The generic obd2 function on it would not connect to car, but I managed to run the health check and pulled several codes, hRiver the P0A90 that my scangauge found was nowhere to be seen on tech stream. Here is a few photos of the codes I pulled.
    Any suggestions where to look next? I have a new crank sensor to put on so will probably try that and go over the wiring there.
    I charge the 12v battery but after sitting with ig on for 30 min it drops to 8.9v could this be the culprit? Would a low battery cause car to die whilst driving?
    I cleared the codes after saving them but car still just makes a whirring noise from inverter side of engine and does t start.
    Any help is very much appreciated, I’m borrowing a car but can’t for much longer, I’m hoping to get mine running rather than buy another clunker.
    SFO likes this.
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Charge up the 12v again, then use techstream to retrieve the latest round of codes (DTCs). Please post them here.
  5. daley
    daley Junior Member
    60
    Knoxville
    Sorry I have been snowed under with work and not had chance to look at car.
    I had it on charge for a day and never did anything to it. I just went to see what codes I am getting and now I have
    Po335 - which I believe is the crankshaft sensor.
    B1421 - which is something to do with the AC.
    C2318- low voltage at transmission module.
    I think the low voltage is the battery, I keep charging it and getting 12.5v or more but it isn’t lasting long, I think I’ll bite the bullet and get a new one.
    I put a new crank position sensor on but I’m not sure if the harness is fully working, I posted my findings about it above.
    Would a low 12v battery cause car to die on the road?
    Would a crank sensor fail and cause it to die on the road .
    Here is a video of what it sounds like when I press ignition for ready mode.
    I think my next plan is to get it in garage and trace the wires to crank sensor and see if I can see any damage and try a new battery.
    I do wonder if transmission has gone out on me or if hybrid battery doesn’t have enough power, does the noise in video mean anything to anyone?
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,089
    1,997
    NJ-USA
    I would watch the crankshaft pulley and water pump belt and see if the engine is trying to rotate when the car is placed in "ready". You have a pronounced "bad sound" when the engine should be spinning at 1000 rpm and running, that would make me think that there is a mechanical fault. Since you can move the engine by hand then you likely have something failed in the trans.
  7. daley
    daley Junior Member
    60
    Knoxville
    Thanks for your help, appreciated.
    I think once I get it in barn, I will pull engine/trans and replace, used engines/transmission aren’t so expensive.
  8. daley
    daley Junior Member
    60
    Knoxville
    I wanted to conclude this, I replaced engine and transmission with a used one I found that has 80k on it. Just got it in and car is working!
    SFO likes this.
  9. Avantis
    Avantis New Member
    West midlands
    Hi Daley
    Did you strip the engine transmission down to locate the fault, please help as I have similar problem that's unresolved for over 8 months now.
    SFO likes this.
