P0A93 Inverter pump failure, updated pump died.
Discussion in 'Gen 2 Prius Main Forum' started by George W, Sep 5, 2020.
  1. George W
    George W Senior Member
    911
    512
    San Antonio
    I am the 3rd owner of a 2008 Prius. The original inverter pump recall happened at about 43,000 miles, with the 1rst owner.
    I'm now at 170K, and P0A93 popped-up 5 minutes after the A/C stopped blowing cold air. I stop the car, reset the codes, and restarted. AC is blowing again, but I don't see any swirling in the reservoir. At 120K+, the updated Inverter pump is history.
    Is this Inverter a DIY project? Special tools? Thank you.
  2. PriusCamper
    PriusCamper Senior Member
    11,119
    4,524
    Pacific Northwest, USA
    Very straightforward and plenty of threads on here about how to do it.
  3. George W
    911
    512
    San Antonio
    Thank you. I see several different manufacturers. Is this a part that should be OEM only?
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Yes.
    donbright and George W like this.
  5. George W
    911
    512
    San Antonio
    I actually saw the failure before the car began failing. I stopped at the gas station and saw pink fluid right behind the driver's front tire. When I looked in the reservoir, it was full.
    After refueling I drove the car for another half hour before the air conditioning stopped. Looking up the code, the P0A93 indicated Inverter pump, but yet the reservoir is full.
    I'm a little confused as to how there was a puddle of pink fluid underneath the pump and yet the reservoir still shows full. Does the inverter pump contain a one-way valve?
  6. edthefox5
    10,096
    4,806
    Clearwater, Florida
    The engine coolant is the same color. You may have a bad engine water pump very very common.
    Disregard the overflow.
    Take the plastic cover over the radiator off. Underneath that is the radiator cap on the left.On a cool car open the cap and make sure the coolant is the top of the neck.
    If its low you probably have a bad engine water pump too. Get a flashlight and look at the front of the engine make sure the water pump belt is there then look closely in that whole area for green or red specks which is the water pump weep hole is losing fluid which means the water pump bearing is blown..
    George W likes this.
  7. George W
    911
    512
    San Antonio
    That is going to be my tomorrow project. Thank you very much.
