P0A93 inverter pump replacement.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Michael Bones, Dec 8, 2024.
  1. Michael Bones
    Michael Bones Junior Member
    42
    Los Angeles
    Good afternoon folks. It's been a while since I've posted anything but I wanted to share a quick experience, a tip and a little question as well. A couple of days ago I had my dash light up with the triangle of death and as we all know that can be heart stopping. My 2007 prius lost power but fortunately I was in a decent spot to roll to the curb. I'm so paranoid these days that I actually have a OBD2 scanner with me all of the time these days. I quickly read the code as a P0A93 which upon I saw it was the inverter cooling pump issue. I then turned of the car and then turned it back on. It went into ready mode no problem so I cleared the code and went about a block into a gas station lot. When I checked the inverter reservoir there was absolutely zero turbulance so I decided to check the appropiate fuse after looking up a diagram and it was still good. Well....Time to use AAA to get my car home. It was late and I was tired. So in the morning I started chasing the OEM pump. On ebay there were a few OEM options. Two stuck out at around $110 and one I noticed was available for immediate pickup but the damn DEALER was 60 miles away. Now here is where the plot thickens. My local dealers wanted anywhere from $245 to $275 for the same part....Wth!
    Upon doing some research and confirming with the parts manager at the dealer 60 miles away that the pump was in fact OEM and the unopened box clearly said the part was made in Japan I jumped in my backup car and drove the distance to pick it up.I have attached three pics. The receipt, the box with the label and also a pic of a little washer taped to the inside of the box lid that I cant figure out what it is for so maybe someone can enlighten me. I have decided to go with the actual Toyota coolant for the refill but that will have to wait until tomorrow since it's Sunday. I hope my local dealer isn't too outrageous on the price. Another thing that I think is noteworthy is that on all of the youtube videos I watched about replacing the pump it looked like a real pain to get into the tight spot if you have big hands so I went ahead and pulled the left headlight out of the car which took about an extra 10 minutes and the pump access is a breeze then.
    Questions.....
    What is the little washer for?
    Why is there such a huge price difference between dealers for the pump?
    How much does everyone think the Toyota super long life pink coolant should cost? One more thing that I think is noteworthy is that the dealer only has the part# G9020-47031 but on the box at every dealer the original number part number 04000-32528 doesn't even come up in their data bases.
    #1 Michael Bones, Dec 8, 2024
  2. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    The huge price difference is immorality/corruption plain and simple. These are cheap dumb pumps that has the lone technical challenge of making sure less than boiling hot water it pumps doesn't cause premature failure.
    Long ago I decided on a policy of only using the cheap $30 aftermarket pumps for people because once you get the hang of it and use hose clamps in the right way you can swap them out in a 1/2 hour and while these cheap pumps sometime fail prematurely it's never happened more than once per vehicle and even in that instance paying $60 for two pumps and an hour instead of a 1/2 hour labor is way more affordable than the criminal activity that the Toyota Stealerships are engaged in.
    Lastly, your inverter has a high temperature shutoff so it's perfectly safe to drive around in cold weather. One of the top experts who used to be on here also suggested if you have to drive further than amount of time it takes inverter to heat up you can put a bag of ice on top of the inverter to buy you some more time. I tried that once, seems to work fairly well.
    Up here in the PNW most people don't even know their inverter pump failed in the winter and it takes till late Spring when weather is up above 80 for the P0A93.
    6079smithw likes this.
  3. Michael Bones
    42
    Los Angeles
    Thanks for the input. Clearly you are a veteran at doing this but since it was my first time I decided to go with the OEM for the $120 which is extremely high for what you are actually getting. I was in the aftermarket auto repair business for 36 years before I retired and the nearest I can figure out is that Gen2 priuses are now at a minimum of 15 years old and a lot of dealerships move their existing inventory of 15y + parts to an obsolete line code meaning to say they will not keep filling their stock of those items any more in order to make room for newer vehicle parts. Its possible that once a dealer makes the stocking line code change to the "OBS" line code then they decide to drastically mark up the parts. At least that is the way the transmission parts company I worked for handled things. All of that out of the way .... do you know what thart silly washer was for? What are your feelings on the replacement coolant?
    #3 Michael Bones, Dec 8, 2024
  4. Tombukt2
    Tombukt2 Senior Member
    12,211
    2,153
    Durham NC
    The washer goes to reservoir flange no need touch it . Put washer up probably never use. On LA this time of year should have been no issue.
  5. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    It is a crush washer to replace the one on the inverter/transaxle coolant drain plug. The crush washers are a single-use item.
    If you haven't replaced the coolant within the last 80 to 100,000 miles, you should replace the coolant otherwise, just clamp the hoses.
    Regarding your part number question, the 04000-32528 part number is for a campaign and is identical to the normal G9020-47031 part, only cheaper. It has a few extra bits and pieces to complete the campaign service. The (04000-32528) part is not usually visible in the retail catalogue.
    #5 dolj, Dec 9, 2024
    Brian1954 likes this.
  6. Tombukt2
    12,211
    2,153
    Durham NC
    If that's case certainly do not touch it . There's never been anything in they're except red coolant from Toyoda . Wen mess with it you just wanna change wat ya dropped . It'll be about 34 years till it shows on a test strip that it out of range . Trans fluid another story . Engine coolant different story . They all separate . Godd for no unesscesarry maintenance.
  7. Michael Bones
    42
    Los Angeles
    Thanks for the input folks on the crush washer. I will probably do a coolant swap next spring but for now Im just going to finish up the inverter pump swap. I do have another quick tip for you all if you are in SoCal. If you order the coolant online through your local Toyota dealership you can save almost $10 on the 1 gallon bottle. You have to choose pick up in person to get the whole discount but even if you were to choose to have it shipped to you the $10 should cover the freight.
