P0A93 P0420 errors
Discussion in 'Gen 2 Prius Technical Discussion' started by enginestarter, Aug 13, 2019.
  1. enginestarter
    enginestarter Junior Member
    66
    UK
    Active
    I got these errors: P0A93 P0420 errors.
    I need advice on what to do.
    On another thread I asked about the P0A93 error. I was going to buy the pump and replace...
    But... a friend said: reset the error, drive around... if the fault is there, it will just come back. Only then replace.
    I reset. Didn't come back.
    Then... 3 weeks later, I was driving somewhere long distance... ping... it came up.
    Someone else (neighbour who's a private car dealer) told me to reset again.
    All great!
    AGAIN: long distance drive it came up.
    This time, I didn't reset. I drove around. The next day... it just disappeared - both errors.
    I looked up P0420 - says the cat converter isn't reading values.
    I had my cat converter stolen and had replaced with a Klarius.
    I thought I would mention.
    What should I do??
    I'll definitely replace pump now (unless someone says otherwise)
    Could the P0420 error be related to the P0A93 error?
    Thanks.
  2. enginestarter
    66
    UK
    Active
    52,386
    i think you should buy the pump
  4. spdracrm3
    spdracrm3 Member
    58
    47
    estacada or
    Replace the pump for sure as the valves are intermittently sticking
    The cat code is most likely due to aftermarket cat not being good enough to satisfy the ECU . Might try to find a used good factory catalyst
    SM-G960U ?
  5. enginestarter
    66
    UK
    Active
    Thanks for the replies guys.
    Pump: I'll buy and fit.
    The cat: after doing many hours (days!) of research, I took advice given on this forum and got a Klarius.
    I got from Eurocarparts (as I bought through someone who worked their, I got a massive discount).
    I really hope it's not failing.
    It cost me £110 to get fitting by a mobile mechanic.
    I don't fancy forking out on another cat converter + pay for fitting again.
  6. JC91006
    16,827
    8,600
    Your mechanic neighbor doesn't know much about the prius to be giving you advice. I'm surprised you haven't been stranded yet with the failed pump. Maybe you should roll the dice and go on a cross country road trip?
    Resetting turns off the warning computers give you, doesn't fix the problem. The inverter pump function is to cool the electric motor, which is a vital part in making the car move.
    What you're doing is the same as disabling a carbon monoxide alarm when it beeps, then without beeping sounds there should be no more carbon monoxide danger. Problem solved?
    But worse car scenario, you just buy a used inverter when you're stranded 1000 miles from home, they're cheap on the used market.
    Skibob and Raytheeagle like this.
  7. enginestarter
    66
    UK
    Active
    @JC91006 heard loud and clear.
    One last bit of advice: should I buy a used pump instead of a new cheap one from ebay?
    Thanks.
    (Neighbour, he's a nice chap, not an expert on Prius.)
  8. dolj
    dolj Senior Member
    8,555
    4,346
    Wellington, New Zealand
    Go cheap Ebay if you like replacing the pump frequently. Buy OEM if you want it to last 100,000 miles. Your choice.
    Skibob likes this.
