P0A94 code. DC to DC converter Performance
Discussion in 'Gen 2 Prius Technical Discussion' started by kens97uber171, Jun 23, 2021.
  1. kens97uber171
    kens97uber171 Active Member
    177
    133
    US
    Was driving on highway. Hit gas to pass,. Sudden loss of power.. Red Triangle, and ABS , VSC, Check Engine light all on. Gas engine does not start. BUT the car moves electrically.. fortunately the hybrid battery was mostly full.
    Any suggestions.. Tech stream did not show any sub codes I don't thing.. not that I saw. Clicked on everything I could.. got some freeze frame data or live data. But that's it.
    Any suggestions on things to check before just replacing the Inverter Converter?
    Car has 371,000 miles. 20210622_134029.jpeg 20210622_135013.jpeg 20210622_081840.jpeg
    52,406
    is it out of gas?
    PriusCamper likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,088
    5,308
    Pacific Northwest, USA
    Gas is almost as important as cookies!
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    I see 6 dots on the fuel gauge...
    the subcode will be in the freezeframe data screen
    that sure is a lot of codes, would hate for you to start swapping out an inverter just to find out it doesn't solve the problem.
    Are all of these new or previously existing?
    Brake codes
    Communication loss codes
    Air bag codes
    Not too worried about the C2122 since the black tape explains that one :D
    All over the place but what do they have in common?
    #4 TMR-JWAP, Jun 23, 2021
    Meg&Bear and PriusCamper like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Did you click on the snowflake icons:whistle:?
    Sounds like an inverter pump to me;).
    But confirm with the INF codes present on the freeze frame screen(y).
    Meg&Bear likes this.
