P0A94 error code
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by easternk9, Jan 17, 2025.
  1. easternk9
    easternk9 New Member
    united Kingdom
    ----UK----
    Newbie here. My 59 plate (2010 model, 167,000 miles) has died and the display has lit up like an xmas tree. unable to start unless I attach a booster pack. message on dashboard as well saying check hybrid system.
    I want to get it fixed, but am unsure about what to do - do I risk the bill from Toyota or try an independent specialist? I am also unsure how 'major' the issue is. The error code from the breakdown company is attached.
    Thanks in advance for anyone who is able to try and assist me.
    52,383
    you'll need someone with a prius aware scanner to read the sub codes.
    might just be a bad 12v. was there an extended warranty on the ipm module there?
