P0A9C code
Discussion in 'Gen 2 Prius Technical Discussion' started by Jonscheets, Oct 30, 2017.
  1. Jonscheets
    Jonscheets New Member
    Cherry Hill, NJ
    Hello all,
    Recently removed my traction battery, replaced a cell, balanced the pack and reinstalled. Everything has been going great, 45mpg with my lead foot, battery appears to charge/discharge well. Put about 500 miles on the car and then I got the game triangle of death and other lights. Download code P0A9C HYBRID BATTERY TEMPERATURE SENSOR "A" RANGE/PERFORMANCE. The fan understandably stays on now.
    I remember when I removed the pack, the sensory wire on the bottom wasn't really attached to anything, so I attached it to the fan end of the battery. That's the only thing I can think of that was abnormal.
    When I get time, in going to remove the traction battery and check the sensory wires on top and bottom, but is there anything else I should look for? I searched the forum and there isn't much help with this code. Thanks!
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Might also want to see/check if the HV Fan has been cleaned lately.
    Prodigyplace and Raytheeagle like this.
