P0AA6 2008 prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by reyada4766, Mar 5, 2022.
  1. reyada4766
    reyada4766 New Member
    22
    victorville
    I tried disconnecting the A/C and the code still apperad. Any common failure points that create this code? I don’t have the tool to get the subcodes. Mpg is 32 not sure if this is related. Since used cars are over proced I might as well fix this one as cheaply as possible
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,212
    5,902
    Columbia, SC
    In a 2004-2009 Prius, the P0AA6 is caused by the HV battery about 95% of the time. Usually one or more of the 28 individual modules inside the battery has an electrolyte leak/seep that manages to contact the steel case. This causes a reduction in the isolation between the HV system and the car body, which triggers the code.
  3. ChapmanF
    15,561
    Either a tool for reading the subcodes, or a tool for measuring megohms, or both, will be basic tools for this job.
    Not having the tool isn't an insoluble problem.
  4. reyada4766
    22
    victorville
    Thank you. The car is worn. I Just posted pictures on the200,000mi club plus. It shows the damage on the car.
