P0AA6 526 614 AC ISSUE FIX
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Brucetafer, Jul 17, 2021.
  1. Brucetafer
    Brucetafer Member
    126
    59
    Orlando Florida
    Unfortunately I was in a hurry to get the car done but I grabbed some pics to help fix this AC issue so many are having across the Toyota Lexus products.
    There is a pressure / vacuum relief hole in the plug, which is a perfect place for ingest especially if you wash your engine like most of us have done..
    unfortunately the bolts used are a PITA!!! but I got around them with a 5.5MM and 7MM 12MM and a 3MM HEX (Allen) Key, and a PH2 driver.
    Also you will need soldering skills if you want to do a professional job and guarantee success.
    I fortunately have a full electronics workbench so I was able to fix / complete this job in 6 hours.
    My compressor had about 1/2 cup of water in it, the AC still worked fine, but it was throwing the dreaded triangle and pull over check hybrid system.
    You will need to desolder the plug, and the wiring connection ( 4 bigger solder joints, needs some serious heat to remove )
    as you can see there was some serious corrosion and damage but it all reflowed without a hitch and cleaned up perfectly in the ultrasonic bathtub. It also helps to include a rubber ducky and blast some hank Williams jr to remove the crud..
    ask questions and ill answer if you need help. im exhausted and ill update after I wake up.
    IMG_20210716_185903259.jpg IMG_20210716_185926297.jpg IMG_20210716_191711722.jpg IMG_20210716_192042500.jpg IMG_20210716_201216200.jpg IMG_20210716_220556680.jpg IMG_20210716_220601594.jpg IMG_20210716_220613318.jpg IMG_20210716_231902414.jpg IMG_20210716_232809055.jpg
    #1 Brucetafer, Jul 17, 2021
  2. ChapmanF
    15,568
    Nice work!
    What did you end up reflowing? Only the joints you had to desolder to take it apart, if any? How many were those?
    What did you use for heat sink compound, and how did you select it and decide how much/how thick to apply?
    Tim Jones likes this.
  3. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Hard to believe there are that many parts in there....
  4. ChapmanF
    15,568
    There aren't in the Gen 2. :) There's essentially just a three-phase AC motor to turn the compressor, and a DC-to-three-phase-AC inverter or variable-frequency drive circuit that receives speed commands from the A/C amplifier and generates the drive waveforms for the motor. That's what that circuit board is.
    In Gen 2, that circuit was inside the car's main inverter assembly, and the compressor was just a dumb three-phase motor. Gen 3 just moved that circuit out of the main inverter assembly and into the compressor itself, where it can be cooled by, hey, actual refrigerant being pumped over that heat sink.
    ... and that's kind of the story of why the Gen 3 main inverter assembly had a price drop compared to Gen 2, and the Gen 3 compressor had a price increase of about the same amount. :)
  5. tony_2018
    tony_2018 Member
    204
    61
    What thermal paste and where did you get the replacement gasket? I still have my old compressor so I might take this on.
  6. ChapmanF
    15,568
    Does the rubber ducky go in the ultrasonic bath with the circuit board?
    How clean does the duck get?
  7. Brucetafer
    Brucetafer Member
    126
    59
    Orlando Florida
    I reflowed the whole thing just because I can, but most likely you won't need to reflow anything other than corroded parts, LV connector (CN100) / HV wire connection (CN501, TP501, TP730) and HV AC W,V,U connector. I used 60/40 Sweet Juicy LEADED solder, acidic rosin flux, and high ph alkaline cleaner, then bathed in an ammonia based ultrasonic cleaner. I used non conductive thermal paste, its an industrial company that went out of business years ago but I have a TON of it from my old job. the grease that denso uses was dried up and crusty and water based.. like AvE says, the bigger the gob, the better the job..
  8. Brucetafer
    Brucetafer Member
    126
    59
    Orlando Florida
    nope used the original gasket after I cleaned it completely as its not under pressure or vacuum, its more of a dust shield / insulator.. the cases aren't even lapped..
  9. Brucetafer
    Brucetafer Member
    126
    59
    Orlando Florida
    the rubber ducky unfortunately didn't last the war and is swimming with angels.. /Play Taps
  10. Brucetafer
    Brucetafer Member
    126
    59
    Orlando Florida
    what's hard to believe is how many revisions of this style of compressor there is. the more I look the more I find..
  11. Brucetafer
    Brucetafer Member
    126
    59
    Orlando Florida
    yep, that's why I tried to post up as much info as I could without doing my normal meth style 100 page reverse engineered summaries that I usually do for work.. my 2nd gens make me so happy after dealing with this stupid 3rd gen.. good news is my 2007 decided to throw a cat code 2 days after I finished the 2013.. looks like I have to drive the 2009 touring for a bit ( I hate putting miles on her )
  12. ChapmanF
    15,568
    Comparing that to Toyota's instructions for the thermal grease on the main inverter IPM, I have to say AvE's approach sounds more fun!
  13. Brucetafer
    Brucetafer Member
    126
    59
    Orlando Florida
    good lord what a skimpy bit.. I remember reading build sheets that showed absolutely mind boggling designs, thinking, no freaking way this is going to work / last beyond warranty... yet those are usually the products that last the longest somehow..
  14. privilege
    privilege Active Member
    659
    169
    Birmingham
    cool ! thanks for the hot_to_fix_pressure_washed_ac_problem !
    Brucetafer likes this.
  15. ChapmanF
    15,568
    I've always kind of assumed they're going for the minimum layer that, when the parts are clamped together, will fill the micro-irregularities in the metal surfaces, but without being thicker than that or holding the surfaces apart. The thermal grease may be better than potato salad at conducting heat, but you still might not want an unnecessary thickness of either.
  16. tony_2018
    tony_2018 Member
    204
    61
    I see that too but I believe that the same compressor was used for the C, V and the regular prius. They just used a different cover. The cover I'm talking about is the one that faces the passenger side. The Denso I bought had a smaller opening and the Prius Four ac line didn't fit it. I said **** it, swapped them both and it worked out fine.
    In a couple months when the weather is cool I'll be draining the compressor and putting fresh fluid.
  17. tony_2018
    tony_2018 Member
    204
    61
    And the thermal paste?
  18. lech auto air conditionin
    830
    601
    261
    san francisco
    And that’s why when customers allow their AC refrigerant level to drop that nice cool stream of refrigerant stops being supplied to that heat sink and motor windings.
  19. lech auto air conditionin
    830
    601
    261
    san francisco
    It looks like there was some leakage water intrusion causing corrosion on the circuitboard.
    What type ultrasound solvent cleaner was used or did just use plain water deionized or distilled.
    I assume like the rest of the world they’re using leadfree solder which sucks and more fragile.
    Did you re-flow using leaded solder ? To make it easier and more reliable. Or just re-flowed what was there ?
  20. lech auto air conditionin
    830
    601
    261
    san francisco
    Answered my question
