P0aa6 613 code
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jungenas, Oct 3, 2021.
  1. Jungenas
    Jungenas Junior Member
    Ireland
    yesterday my prius got p0aa6 613 code, it still drives the same, i can start ir again after i shut it down. After i erased the code it came back after about 5miles. As i understand its transaxle problem. But its giving me orange warning light check hybrid system. Is it common when transaxle goes bad that the code is not permanent? Im hoping maybe its just loose wire somewhere. Any thoughts would help. Thanks.
  2. Jungenas
    Ireland
    Checked the wires on the inverter and main wires on the battery, no corrosion, not loose.
  3. Jungenas
    Ireland
    Another update. Drove about 10miles again, didn't get any code, but noticed that when i shut my car of, and turned ignition on, torque app showed aux battery lowest voltage 10.5v. Which i think after 10mile drive is very low. Ill just hope its aux battery fault and try to replace it next week.
  4. ASRDogman
    ASRDogman Senior Member
    6,084
    3,271
    You'll get all kinds of strange things happening when the 12v battery is low.
    It's probably old and should be replaced.
  5. Jungenas
    Ireland
    Used multimeter on battery terminals , 40min after car was parked.
    Everything off - 12.13v
    Acc off lights on - 11.63v
    Acc on lights on - 11.59.
    Not sure if its normal on prius, but from my experience with cars that were not hybrids i think its low.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    3,456
    1,503
    NJ-USA
    A fully charged AGM battery should show 12.6-12.8V, depending on the ambient temperature. Yours should be charged (overnight with a proper "smart" charger then load tested, or if it's more than 4-5 years old I would just replace it.
  7. ChapmanF
    15,562
    Corrosion and looseness are not likely suspects for this type of code. They are good suspects when the problem is electricity not being well conducted where it should be. But P0AA6 is a code about electricity being conducted where it should not.
  8. Jungenas
    Ireland
    Little update, got no codes for almost a week, then got the code again, ordered new 12v battery and swapped today. Old battery was 20ah, made in 2014, leaking and wrong type. So im happy i decided to start with the battery first. [​IMG]
  9. Jungenas
    Ireland
  10. bisco
    49,435
    nice handle
    Paul E. Highway likes this.
  11. ASRDogman
    6,084
    3,271
    Mmmmm, post #4..... :whistle:
