P0AA6-614 code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by daley, Mar 4, 2021.
  1. daley
    daley Junior Member
    Knoxville
    Hey folks,
    I am at about 1000 miles on a recent used engine/trans/inverter replacement and now I have triangle of death.
    car started with triangle on and vsc light. I drove car half a mile and parked it. Now all lights are on and it won’t start.
    I have the following codes
    P0AA6 - 526-614
    P0A08 - 264
    P3108 - 535
    everything I have found in search’s points to the inverter.
    I put a brand new toyota inverter coolant pump on when I switched the engine and that appears to be working ok, I feel it on and see movement in the coolant tank.
    many suggestions before I tear out inverter?
    Is there any wiring I can check?
    Many thanks
    Daley
  2. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Sounds like you're already using techstream as an OBD2 scanner.
    Here is the workup for DTC P0AA6 (or P3009) : https://attachments.priuschat.com/attachment-files/2018/04/145252_2006_Prius_RM_-_P0AA6.pdf
    Here is the workup for DTC P0A08 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/21bpm/0a08264.pdf
    Here is the workup for DTC P3108 with INF 535 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/21bpm/3108535.pdf
    Try disconnecting the 12v at the battery for a couple of minutes, and see if the vehicle starts, and then fails to start a second time.
    Raytheeagle likes this.
  3. daley
    daley Junior Member
    Knoxville
    Thanks for the info, much appreciated.
    Looks like I need a new inverter regardless going by the P0A08 code fix.
    I disconnected 12v for 10 min and car starts fine now with no lights.
    Waiting to see what tech stream shows.
  4. daley
    daley Junior Member
    Knoxville
    Tech stream came back with b1421 and b1271 which seem unrelated to inverter.
    I guess I’ll drive around some and see what happens.
  5. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Will the vehicle restart a 2nd time?
    How many miles on the vehicle, and is the HV battery still OEM?
    Do you have issues powering the vehicle on / off, or does the dash / combination meter not illuminate all the time?
    Here is the workup for DTC B1271 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/21acw/cib1271.pdf
    Ignore DTC B1421 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/2044g/cib14212.pdf
    Not sure if the following link had updated workups or manuals (the above links are pretty dated). I've never used the following link, but it should contain *everything* you need : Service Manuals - Google Drive
    It would be great if someone could extract the manuals from Gdrive and back them up on http://mega.nz/ as well.
  6. daley
    daley Junior Member
    Knoxville
    I’ve driven it 15 miles, starts fine second and third time, mpg 43 no warning lights.
    car has 253k, original hybrid battery.
    Engine, trans and inverter have approx 80k on them.
    My inverter coolant level is slightly below low, I am on my way to get more coolant now. It got low due to a split hose, but I caught and repaired it before much coolant loss occurred.
