P0AA6 DRIVING IN A FLOOD
Discussion in 'Gen 3 Prius Main Forum' started by franken1313, Jul 9, 2018.
  1. franken1313
    franken1313 Member
    216
    26
    US
    I recently drove in a flood and while driving I got check hybrid system. I have dtc code P0AA6 'hybrid battery voltage system isolation fault'. What do I replace???
    49,445
    probably a high voltage leak, maybe a/c compressor. maybe the hybrid battery. i don't think water could get into the tranny, but not sure. how deep was the water?
    your car is unsafe, high voltage is leaking to the chassis. i would not drive it until the fault has been located and repaired. someone else posted a tsb on troubleshooting and repairing a flooded car.
    you need tech stream to read the sub codes.
    all the best!(y)
    #2 bisco, Jul 9, 2018
    Johnny Cakes likes this.
  3. franken1313
    franken1313 Member
    216
    26
    US
    The water wasn't that deep maybe at the rocker panels.
  4. franken1313
    franken1313 Member
    216
    26
    US
    I have Autel Maxidas DS808 can this read the subcodes?
  5. bisco
    49,445
    no. look through the battery threads, there are a few obd scanners that will work. torque, iirc.
  6. ETC(SS)
    6,553
    The car.
    (sorry....couldn't resist!)
    The problem in your case probably is not how deep the water was, but rather what kind of bow wave you were producing, and where all of that water was going.
    My thinking is that you clear the code and see if its recurring, and then see of your fault is in the battery or the "transmission" which will give us an indication on next steps....
    Do you happen to have a megohmmeter?
    Back when dinosaurs roamed the earth they used to have crank handles on them, and 99.99999999999999999 percent of the time we used them for purposes OTHER than checking wires for insulation problems.....:D
    There's a small chance that this problem will self-clear.....but there's a HUGE chance that some unscrupulous dealer......which is to say nearly ANY dealer will see this code and immediately jump to the traction battery.... so be careful!
    Good Luck!
    #6 ETC(SS), Jul 10, 2018
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,225
    5,909
    Columbia, SC
    Wow, does this bring back memories of the used-ta-fish 606 and 719. Here, hold these leads for a sec.....followed by a quick crank
    Been on both ends of that experience....the crazy things guys do when bored from poking holes in the ocean.
  8. ITBland
    ITBland Active Member
    433
    272
    New Orleans, La area, US
  9. ETC(SS)
    6,553
    Yeah, right?
    I was a boomer weenie (Chicken of the Sea) but my brother was on the Green Thing (614) and the front half of the USS Sanfranlulu (718)
  10. franken1313
    franken1313 Member
    216
    26
    US
    I ran the test and the code comes back while on neutral. So that means the high voltage battery. What would be the next step?
  11. bisco
    49,445
    pull the battery out and open it up to assess the situation. be careful, high voltage is DEADLY!
    Raytheeagle likes this.
  12. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    My guess is from the HV battery pack area.
    The contractors and the ECU might have shorted out from the flooded water.
    That would have also, if you aren't lucky, discharged the battery pack.
    If you don't attack this problem with the attention it deserves, you might end up, having the complete pack replaced.
    Bear in mind that rate of corrosion or damage on the HV battery system components, increases with everytine delayed.
    You may be replacing some few stuffs in there.
    I have handled some highlanders, prii, and camries with flooded battery pan.
    These pictures might help.
    PIC 1-2: HV contractors corroded due to flooded water
    PIC 3: Battery pack on display showing extent of corrosion
    PIC 4: Shorted out ECU
    PIC 5: Level of flood on the highlander
    IMG_20180522_084829.jpg IMG_20180522_085044.jpg IMG-20170725-WA0005.jpg IMG-20170725-WA0006.jpg IMG-20170724-WA0001.jpg
  13. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    :eek:
  14. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    OMG! I was eating some sandwiches, that was y!
    Contactors
    Grit and bisco like this.
  15. franken1313
    franken1313 Member
    216
    26
    US
    The car is driving fine. The battery seems fine also. The cruise control doesn't work and the EV, ECO & POWER MODE mode buttons do not work that's the only thing.
  16. franken1313
    franken1313 Member
    216
    26
    US
    I can get a hold of a megohmmeter
  17. franken1313
    franken1313 Member
    216
    26
    US
  18. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    See that snowflake on the left;)?
    Click on it and then see the sub codes on the next screen(y).
    Grit and m.wynn like this.
  19. franken1313
    franken1313 Member
    216
    26
    US
  20. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    From the subcode you showed, it appears you have an insulation problem within the car's HV system.
    The likely areas could be any of the following:
    Frame wire•System main relay•System main resistor•HV battery assembly•Electric inverter compressor•Battery ECU•HV transaxle assembly•Inverter with converter assembly•Main battery cable•No. 2 main battery cable•Battery plug•No. 2 frame wire•Junction block.
    Since the problem came up just when you went through the flood, my quess could be that the problem might be on the HV battery pack area.
    Have you opened up the cover of the pack to assess the pack itself?
    Can you post the fatalist of the info from your tech stream here please?
    Dxta
