P0C73 code, inverter coolant not moving
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Arob21, Apr 26, 2022.
  1. Arob21
    Arob21 New Member
    24
    Washington
    Hello everyone, I have code P0C73. The coolant in the inverter pump is not moving.
    I bought and installed a new inverter pump thinking that it would solve my problem. But unfortunately it didn't help the problem.
    I'm looking for advice on how I should go about troubleshooting this issue. I have checked and replaced all fuses under the hood and inside the car that were bad or looked questionable.
    Does anyone have some sort of wire diagram for it? Or a good way to troubleshoot it?
    52,372
    is there 12 volts at the pump connector?
    is it an oem pump from a dealer?
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,490
    6,576
    Texas Hill Country
    The wiring is fairly simple.
