P1116 Hell! Please help!
Discussion in 'Gen 2 Prius Main Forum' started by Adam Morrill, Jan 21, 2022.
Tags:
  1. Adam Morrill
    Adam Morrill New Member
    2007 Prius, 236000 miles
    We had to replace the main water pump a few months ago and then a shortly after we got the lights of death and needed to replace the inverter water pump.
    Now we keep getting the P1116 code.
    I’ve replaced the coolant storage tank sensor, code came back
    I’ve replace the 3 way control valve, code came back
    Any suggestions on what next?
    49,542
  3. ChapmanF
    15,722
    Replace things only if they are proven faulty as you follow the troubleshooting steps for the code. Saves money, time, and frustration.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,487
    1,587
    NJ-USA
    Trying to diagnose problems with the coolant heat storage (CHS) system really requires a copy of the service manual, and having Techstream scantool software (and a mini VCI cable to connect to the car).
    The code indicates that the ECM doesn't see the temperature reading at the CHS sensor change when it expects it to. So, some possible causes are; a clog in the system, the 3-way valve doesn't work right (or has the hoses switched around), the electric CHS pump doesn't work, or a problem with the sensor or the wiring.
    If you have Techstream, then you can look at the temperature sensor data, then turn the pump on and watch for changes. BTW, do you hear the coolant pump run for a few second when you: first turn the car on and then after you turn it off?
  5. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
