P195/60/14 Psi??
Discussion in 'Generation 1 Prius Discussion' started by nitewolfgtr, Sep 29, 2008.
  1. nitewolfgtr
    nitewolfgtr Junior Member
    61
    Owasso, OK
    I'm thinking about getting the Falken ZE-912 P195/60/14 on my 2001 Prius...
    What PSI should I be running the new tires at?
    Thanks!
  2. jbumps wvu mntrs
    jbumps wvu mntrs PC Superfan
    51
    Morgantown, West Virginia
    This is one of the topics that I have spent a LOT of time looking at (Tire pressure and the best tire to put on as a replacement, winter traction vs. rolling resistance etc...) The general school of thought seems to be a 42/40 set-up. That's not to say that there are not extremes though. Seem to remember some in the 60's-70+ range. Personally I've gone from roughly the low 40's to low 50's for the last few weeks and am getting the best milage yet out of the car (58.5-59 for the last 500 miles). Not sure how much of that is better P&G and how much is the pressure... That's my two cents. And to add one more cent, depending on your traction/weather needs I would consider the Assurance Triple Treads. Excellent treadlife and all season traction while sacrificing the least on RR.
  3. nitewolfgtr
    61
    Owasso, OK
    Yea, I like the Assurance Triple Treads but they don't make 'em for size 195/60/14... :(
  4. Patrick Wong
    18,210
    6,513
    Since 175 width tires tend to show excessive shoulder wear using 35/33 psi inflation, the 195 width tires will probably show even more shoulder wear at that inflation level as a larger width tire is being installed on the same wheels (which would tend to push out the center of the tread even more). Hence I agree that 42/40 psi is a good place to start, assuming that the maximum inflation pressure printed on the sidewall is 44 psi or higher.
  5. NinnJinn
    NinnJinn Member
    276
    Indiana
    Mine are rated for 40psi max... Right now I have all 4 pumped up to 40. Should I do 40 front and 38 rear?
  6. Classic_pri
    Classic_pri Former 2001 Prius 0wner
    124
    36
    Wisconsin
    Agreed on shoulder wear. I had 195/60s on our 2001 (Goodrich Traction T/A) and the tires developed wear on the inside edges. I generally kept the inflation pretty reasonable, too, like 35 PSI. I think the car also took a mileage hit. I do think handling was improved, but if I were to do it over I'd look for a 185/60.
    I liked the Goodrich tires, but they're NLA. They have a successor, though, in the G-Force Super Sport. Tire Rack gives them high marks.
    General has also been making some decent tires lately. Check out the Altimax HP.
  7. Patrick Wong
    18,210
    6,513
    You could do 40/38 or you could stay at 40/40. If you don't notice any handling issues now, then it really doesn't matter.
