P1a80 error code
Discussion in 'Prius v Technical Discussion' started by Canarian CHR, Aug 3, 2021.
  1. Canarian CHR
    Canarian CHR Junior Member
    Spain
    Business Edition
    anyone had this error code or know what the cause could be?
    Thank you very much for your help
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,975
    4,716
    Texas Hill Country
    Sure its not a p0a80?
    Tim Jones likes this.
  3. ChapmanF
    15,614
    What tool was used to read it?
    I've been seeing more and more threads (some say they're using Dr. Prius?) where the second position of the DTC is wrong. Sometimes it's even obviously bogus, like a letter or a number above 3, which the second position of a DTC can't ever be.
    1 at least is a possible second digit, but P1A80 sure isn't a Prius code I've heard of before.
  4. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Traction Battery
  5. ChapmanF
    15,614
    There is very definitely a P0A80 code that pertains to the traction battery. It gets mentioned on PriusChat a lot.
    If you have some inside info on a P1A80 code, then, please, spill!
  6. Tim Jones
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    trani fluid code. happens when the shifting is not as smooth as usual especially when it shifts into 6th gear.
