p219a Intake Manifold?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by oasmith, Mar 29, 2018.
  1. oasmith
    oasmith Junior Member
    42
    22
    Hi Everyone,
    So, in a couple days, i think i'll be taking on the project of cleaning the intake manifold (and EGR pipe, and maybe the throttle body). Here's how i've gotten to this point:
    I noticed a slight shuddering/shaking/sputtering a few weeks back, and it was only at certain RPMs. If i pushed the gas down to really accelerate, it would run fine, and the same for if it was just coasting downhill or a few slight amount of stepping on the gas. A few days after, the engine light came on it had a code of p219a, air/fuel ratio imbalance on bank 1. I was due for an oil change anyway, so i brought it in to the dealer and they did the oil change. Amazingly, i forgot to tell them about the shuddering. Anyway, after the oil change, there was no improvement in the shuddering. I brought it back to the dealer a few days later and they said they'd have to run a full engine diagnostic and that it would take a few hours, so i had to reschedule for another day. After that, i tried two bottles of fuel injector cleaner (one bottle per full tank of gas), and then i replaced the spark plugs (they probably had about 80k miles). None of these things resolved the shuddering, and the shuddering was getting worse over time. I brought it in to the dealer and they ran a compression test. The cylinders had 215, 205, 209, and 205 psi. According to the notes on the service report, these are all within specification range. The dealer said that the likely problem is a bad engine valve and that i'd have to replace the engine, and that is a game over for this car.
    I searched on here for a bit and on google, and i found a couple people describing this exact same symptoms and that cleaning the intake manifold solved the problem. A few more details: 2014 Prius Two, 212+K miles on it, shuddering only happens when using the gas engine, never on the battery (obviously). My mpgs haven't been reduced as far as i can tell, but maybe the fuel injector cleaner helped with the mpgs for those tanks. No knocking or pinging, just shakes badly as certain rpms, and it seems to get worse the warmer the car gets.
    So, just wondering what everyone thinks. Is cleaning the intake manifold a good chance of fixing this? I've already watched the video on the the cleaning process, so i know what's involved. The car has been great prior to this, and i'm hoping i can save it and get to last another 100k. Also, since this issue has been ongoing for a few weeks, have i caused damage to the engine itself?
    Thanks for any help!!!
    Owen
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    egr cooler needs to be cleaned also
    Mendel Leisk and mjoo like this.
  3. Tande
    Tande Active Member
    502
    302
    Mich.
    The Toyota dealer says your cyl. compression tests are all within specs., & then says you have a bad valve?? ......:oops:
  4. oasmith
    42
    22
    Cleaning the EGR cooler would add on a good amount of time, and i don't really have all day to work on the car. I suppose i can clean the opening after i take off the EGR pipe. And, people seem split on whether to replace the PCV Valve. It seems logical since i will have such easy access to it, right?
  5. tankyuong
    1,555
    660
    Central MO
    just take the pcv valve off and shake it to see if it's still good
  6. cnttxmdc
    cnttxmdc Junior Member
    Did you ever get resolution on this? I’m having the exact same issue right now.
    thanks!
  7. ilovegirls
    ilovegirls Member
    173
    San Diego
    I have the same issue too.
    Egr clean
    New o2 sensor
    Cleared it and within 20 miles, check engine light comes back on.
  8. ilovegirls
    ilovegirls Member
    173
    San Diego
    I got rid of the check engine today. This is what I did for this who may come across this issue.
    I took off the intake manifold and cleaned the build up around the ports with carb cleaner. I also took off the little egr pipe and cleaned it. The egr pipe wasn't blocked and it didn't have build up but I cleaned it anyway. Drove it around and the light went off by itself.
    ASRDogman likes this.
  9. ChapmanF
    15,463
    How did the very small EGR passages in the bottoms of the four manifold ports look? Did you clean those?
  10. ilovegirls
    ilovegirls Member
    173
    San Diego
    There was build up around all 4 of the little ports. I sprayed and stuck the little red straw in there to flush it out. I have a feeling it had to do with those little ports.
    wheezyglider likes this.
  11. IDs mak
    IDs mak Junior Member
    31
    Ny
    9 out of 10 times this issue is caused by clogged egr pipe
    And worth cleaning the intake
    Check the pics for before and after
  12. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Unfortunately, spraying cleaner in there alone won't cut it. You have to use something like a small nylon bristle brush, long ones made for cleaning the inside of stainless steel drinking straws, for example.
    Even then, you'll get most of the gunk out that is physically blocking the ports, but there will still be a greasy residue coating the passages.
  13. ASRDogman
    ASRDogman Senior Member
    6,062
    3,254
    Get a .22 caliper gun bore brush. Put it in a drill, battery one is easier.
    Spray gunk on it and in the hole. Run the brush in and out for 5-10 seconds.
    Sray with gunk to clean it out, repeat.
    You'll be finished with all 4 in about 2 minutes. Then flush with a strong spray of water.
  14. Mendel Leisk
    38,651
