P261b and check hybrid system warning
Discussion in 'Gen 3 Prius Main Forum' started by Sneakyx16, Nov 18, 2019.
  1. Sneakyx16
    Sneakyx16 New Member
    Castle Rock, Co
    I recently bought a 2010 Prius used with 204k miles. Previous owner said he had replaced the waterpump himself and showed me receipt for the electric waterpump. I test drove it and it was fine. So i purchased the car drove it home about 1hr drive and it was fine. Next day i drove it to run errands for about 30miles, chk engine light comes on. then check hybrid system comes on. I chk it with Innova scanner and it said bad circuit 261b waterpump. So i tried clearing code and it didn't work. Read alot of forums and i learned that maybe i needed to purge air out of coolant system and it was good for 2 days. then same thing came back. Btw i ended up buying a better scanner autel mx808ts and it showed the water pump was not running. it would show the target speed around 2750rpm and the actual speed read 0rpm. I would clear the code and bang on the waterpump and it would work... then i would drive and it would randomly stop working sometime good for 1hr and sometimes it would stop after 2mins. and i would get stranded. Of course i had my scanner with me and a hammer to bang on the water pump to get it working again.
    My question is Im not sure if its' the waterpump or a thermostat I need. because Im not sure if the thermostat has ever been replaced as I can no longer get a hold of the seller. and water pump does look brand new oem toyota. when the water pump is running, the water pump spins around 2700rpm-4700rpm when car is running. the temputure ranges from 141-190. I notice when the check engine light and check hybrid system pops on and makes me pull over temp is around 202. Also when waterpump does not work, the heater is cold. So do i need a new water pump or just the thermostat you think??? Please save me as this has been stressing me out and i cant find the correct answer in these forums.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    I’d replace both of them with known quality parts (I swapped both the pump and thermostat out on our old 2010);).
    It sounds like the water pump or a connection is causing an intermittent issue if the time between events varies. I’d look around the water pump connection and make sure everything is tight and as it is supposed to be:).
    Any history of damage or previous work other than the water pump:whistle:?
    Good luck and keep us posted (y).
    dig4dirt likes this.
  3. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    When in doubt, change them out
    Next in line, read about the EGR stuff
    Raytheeagle likes this.
  4. Sneakyx16
    Castle Rock, Co
    Thanks guys... i also forgot to mention, when water pump is not running and car temp is in the 200's, the lower radiator hose from the thermostat is not hot. Meaning the thermostat is stuck closed? Could the waterpump not run because thermostat is not opening to let water into it?
